Mitsubishi WS-55909 55" Rear Projection Television Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green blinking timer light continues to fals but TV will not turn on. Have depressed reset, but green light continues to flash
Anonymous
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on Mar 18, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
10822
Points
133
You're going to need to contact a tv technician. you're looking at about a 300-400 dollar repair
3helpful
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Tv problem
can you tell in what patter does the light blinks??
2answers
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
1helpful
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Continuous flashing green "timer" light on front, tv won't reset
Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
http://servicemanuals.vstore.ca/
2helpful
2answers
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
2helpful
2answers
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
