Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
The receiver does not respond to the remote or its buttons; there is no TV display and the V7 is displayed on the receiver's screen.
Posted by kumarm7 on
Anonymous
    Scholar:
    New Friend:
  • 24 Answers
When you're pressing any of the buttons on your DISH Network remote, is there any mode button such as TV, SAT, or AUX,that lights up? To provide further explanation- when you are trying to change the channel up or down, or power on the receiver, as you press any of those buttons the "SAT" mode button should temporarily light up & then turn off to let you know the remote is in the correct mode to control your satellite receiver, this button is in the upper left hand corner of your remote that says "DISH Network" at the bottom. If this is not happening, then I would suggest replacing the current batteries with fresh batteries, if the problem continues with no mode buttons lighting up, then we will need to replace your remote. If you haven't resolved this issue already and need me to order you a new remote for you, please feel free to contact me direct & I will be more then happy to get a new remote ordered for you! Email- [email protected]. I hope this helps!
-Kirstie DISH Network
Posted on Jan 31, 2011
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
Aug 07, 2016 | Fujitsu Heating & Cooling
My lg tv displays V3.10.1 an does not respond to manual or remote control
It is showing the software/firmware version--seems you may have by accident gotten into a place you should not be in---best answer is get LG on the phone with model number and the V3 information---I doubt anyone here will resolve this issue instantly.
Apr 20, 2012 | Televison & Video
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Program name and time displayed across top of screen and I can't get it off.
Not sure which sony tv you have. Assuming its the tv and not a cable box or satellite receiver, there is a usually a button marked display on sony remote. That should clear any On Screen Displays.
Apr 22, 2009 | Televison & Video
Remote controls of 3808Ci do not display menu on TV screen.
ther might be somthing wrong with the button and not the remote or tv so make sure nobody has spilled anything on it or hit it to hard.
Jan 23, 2009 | Denon AVR 3808Ci Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
202 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Sheldon Dedek
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
