Will show blue light from projector, but not image. I have all cords attached correctly. Thanks.
SOURCE: The image projected from my CTX EzPro 680 Projector flickers on screen
From my experiences working with projectors, more than likely you will need to replace the lamp
go to the control panel. Personalization and select the second screen. That usually works for me.
SOURCE: Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
SOURCE: my toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
SOURCE: Blue stain on the image projected by my PLV-Z3
I had the exact same problem with my z3, Turnes out it was the blue filter.
I used the full service manual, and managed to fix mine using the diagrams, and troubleshooting section.
You can get the full service manual here.
http://yama.co.za/forum/index.php?topic=147.0
