Car Audio & Video Logo
Anonymous Posted on Mar 18, 2010
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
  • Anonymous Mar 18, 2010
    Before the amp started blowing fuses the wires kept coming out of the speaker box while I was driving.
  • Anonymous May 11, 2010
    Did you install an second install product since you have the vehicle? Most of the time, you will have to ensure that car has a 12 ignition on the key, cause sometimes some of the reaction of the car may be due to an install trouble between the 12 dc and the 12 ignition. Some car manufacturers did not install a 12v ignition, then the reaction of the electronics applications can be the reason why. If you make any changes, inform cause that can be one of the explanation.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Mar 18, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
6536
Points
21
Well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
seankane89
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 54 Answers
  • Posted on Nov 28, 2017
seankane89
Contributor
Level 1:
New Friend:
Cheetah:
Answers
54
Questions
Helped
20014
Points
73
If the speaker wires touched you have blown output devices. That's why the power supply is blowing your fuse. The amp will need repairs.
1helpful
Rockford Fosgate Punch P1000X5 5-channel car amplifier keeps blowing the in-line fuse?
Internal or external short. Disconnect everything but power, does it still blow? If it does, you need to take it in for repair..
Fuse keeps blowing when power on
You have either shorted outputs or a shorted power supply in the amp.
I got a rockford fosgate 801s. and i cant find where the fuse is located.
Regards, Tony
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
I have a rockford fosgate 550 that the fuse blows
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
1helpful
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Rockford amp cut out
Disconnect all speaker wires from the speaker terminals of the amp and disconnect the RCAs. Replace the 30 amp fuse with a 15 amp fuse. If you turn it on and it blows the fuse, it's likely that it has shorted output transistors. If that's the case, you need to have the amp repaired.
Rockford a2 not powering up
yiur amplifaer is in protection mode you moust reset the amp
Top Rockford Fosgate Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
