Below goes the instructions to connect..
1. First install the USB Cable driver, please do not connect your
cable to your mobile until you installed it correctly. You will receive a
message USB cable driver installed successfully.
2. Then connect your mobile with your pc. A message on your handset
appears with three options.
Mass Storage, COM Port and PicBridge. Select COM Port.
3. Now your PC will detect a new hardware found and a window will
pop up. Select the third option..No, Not at this time then click next.
4. Select installed the software automatically and click next. Wait
for 10-15mins depending of the speed of your PC, until window finishes
installing your modem to the com ports. if a pop window appears in
between then just click "continue anyway tab". Selecting this will not
harm your computer.
5. Now you will see a message "Your modem has been successfully
installed on com 4 or what ever the number it has."
6. Now copy your PC suite to C drive. Actually Micromax Q3 PC suite
doesn't have the installer exe. So you have to copy the whole folder to
the root drive of your PC.
7. Run the PC suite exe. and go to the settings tab on the left hand
side of your PC Suite. select the drop down for COM4 or the COM number
on which your modem was installed and wait for few seconds..
That's it..now you can see your status bar it will show you
"Connected"
Enjoy!!!!
U should install the cd dat u had got with ur phone...after installing the software...then connect ur phone to the pc via bluetooth or data cable...and in the connect to internet option put use name as blank pasword blank and apn as aircelgprs and dial number as *99#
Hallo sir, i have a micromax Q5 fb handset and i have installed pc suit on my pc and use airtel gprs daily pack but i could not connect internet on my pc and not open homepage web on pc. please help me step-by-step at my email [email protected]
thank you.
I am posting all the steps which I did to connect my Micromax Q5 phone with my PC for Aircel Internet.
In my Q5 phone:
Menu -> Settings -> Connectivity -> Data Conn. -> GPRS -> ADD ->
APN: aircelweb
Username: Blank
Password: Blank
HTTP ->
Authentication: Normal
Proxy: No
Then next step:
Menu -> Services -> WAP -> Settings -> Select SIM -> SIM 1 -> Profile -> SIM 1 -> aircel net -> Activate Profile.
Then I can use Internet through my Opera Mini & also throgh WAP homepage.
Now I have insert CD -> Installed -> "Installed Driver.exe"
Its showing Driver Installed successfully.
Next I opened Phone suite -> then gone to Blue icon in the Phone suite folder -> Click on settings -> General -> select port -> COM 1 -> Create connection -> Create/modify ->
APN: aircelweb
Number: *99#
Username: Blank
Password: Blank
New-> Create Connection -> Connection successfully ->
But now what I need to Do?
or Did I mistake anywhere?
