When you start washing the water start leaking from the bottom and the side of the draw and it did activate the flood switch I have replaced the flood switch but i need to know where the water leaking from is there a way of trying the draw cover ( with the rubber seal) if working or not.
To put machine into test mode: Press and hold keylock, then press and hold start button. Hold both in until machine beeps (if you have display, it will show all symbols). Press power button- display should now show HO. Press start button until LD shows in display- this tests lid motors. Activate lid motors by pressing keylock button- if you open drawer about 3 inches, you should see lid come down. Pressing keylock again will raise lid. Raise and lower lid several times by pressing keylock button to ensure lid is working properly- if not, lid motors need replacing. Good luck!!
