Health & Beauty Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to purchase foils No.235 and 410. Also cutters for same. William
shaveroutlet.com
Level 3:
  • Braun Master 1,652 Answers
  • Posted on Mar 18, 2010
shaveroutlet.com
Braun Master
Level 3:
Answers
1652
Questions
0
Helped
765602
Points
4209
These are hard to find parts. You will find foil 410 at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-eltron-shaver-foil-410-p-562.html
To lacate other parts you will need your shaver model or type number to match up
I have a panasonic shaver eslf50k I need an outer foil and inner blade where can i purchase same i live in cape town rsa
You will find this item at shaveroutlet.com at the link below
http://shaveroutlet.com/panasonic-wes9027p-foil-and-cutter-set.html
How often should I change my foil and cutter?
Most foils and cutter needs to be changed once a year, if you have a tough beard you should replace it them sooner. You should change the foil and the cutter at the same time because as your cutter gets duller, your foil gradually gets thinner as well.
1helpful
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
How replace free glider foil and cutter
If you need a foil and cutter set for this model, you will find it at shaveroutlet.com (see link below). Instructions are on the package.
http://shaveroutlet.com/braun-freeglider-series-foil-and-cutter-p-148.html
The instructions for replacing the foil and cutter on Freeglider models are also displayed at shaveroutlet.com. See picture below
I purchased replacement screens and cutters in December. One of the screens now will not stay on. Vibration from the motor causes it to pop off the shaver.
The problem is likely cause by a buildup of whisker particles keeping it from locking into place.
The first thing I suggest is to remove the foils from the frame that they go into. Once removed, thoroughly clean the foil frame and foils and then reinstall them.
If this doesnt solve your problem, there may be a defect with the screens or wear to the frame that the foils snap into. You will have to determing which you need to replace.
If you need to replace the foils, you can purchase replacements at shaveroutlet.com. See link below.
http://shaveroutlet.com/remington-sp96-smart-system-series-foil-and-cutter-set-p-237.html
1helpful
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
I hope you find this Very Helpful and best regards!
1helpful
New foil required for braun 370 travel shaver
Hello MrandMrsInger! You can purchase a new replacement foil for your Braun 370 at the link I've provided below. Basically, you'll be getting a new cutter block and foil for it, as the foils are no longer provided separately.
Braun, now owned by Gillette, discovered that many folks would buy just the new screen (foil) and it would get torn/damaged by a nick in the cutter block blades, so they packaged these wear items as a set to eliminate those very common problems. I had it happen to mine several years ago, so I know why they made the change.
Anyway, here's the website with your replacement parts:
Just scroll down to the 2nd item shown, I believe, and you'll see your replacement set.
You can also use the part numbers to try to locate another supplier, if you wish, as these are the actual Braun part numbers provided.
Hope you find this Very Helpful and best regards!
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
