Question about Samsung HLN617W 61" Rear Projection HDTV
My HLN617W dlp will turn on with no picture (sound is OK), then will seem to turn off, then back on again without me doing anything. After this ritual being repeated, the lamp and power lights will start to blink followed shortly by the red temp light. All 3 will blink and the only way to turn the TV off is to unplug it... any ideas?
Posted by donraby2001 on
Anonymous
    Guru:
  • 416 Answers
The lamp is finished. Order a new lamp using the code on the side of the TV. Remove the lamp door on the back of the TV (4 screws) and then remove the lamp (1 screw). Have a look at the lamp... is it damaged? See my tips & tricks if you want to learn more about the lamp.
Posted on Mar 18, 2010
Inputs no longer getting signals
More common is storms wreck the cable box. But try unplugging power to everything for 1 minute. and retry.
Samsung dlp hl55679w
It sounds that the light engine has the fault. Contact the authorizes service center for Samsung.
5helpful
2answers
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Samsung DLP HLN617W TV does not turn on, all 3 lights flash
In this case it seems you may have an issue with your ballast. Either it's going out or barely starting. I recommend you replace it
Samsung DLP HL-P6163W with no picture
might is not a good word from a tech. there is nothing you can really do yourself without possibly doing damage. browse the Internet for the board at a better price then have him come back and install you will at least save some money. good luck wish this was a quick fix problem if the tv has not been out of warranty long call the manufacturer they might still honor the part.
2answers
61" Samsung DLP w/ no sound
my speakers died some time ago, it wasn't worth fixing, went to a component 5.1 speaker setup. good luck.
2answers
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Our Color TV is now Black & White
it sounds like the main board to me, I can purchase them if you want one let me know
Samsung HLN617W 61" Rear Projection HDTV Logo
Ekse
 Francisco Mauricio...
