Question about White Sewing 2200 Multi-Tasker
Just bought machine earlier today (first purchase of sewing machine). Everything is plugged in and setup correct but it is as if there is no power?
Posted by achievinglif on
paj42
    Genius:
  • 1,116 Answers
Turn on the switch?
Posted on Mar 18, 2010
What does the power cord for my Husqvarna 300 looks like?
What you need to do is look at the plug on your sewing machine. Any cord that you purchase would need the appropriate plug that will fit the one on your machine. If your power cord also includes the foot control, you'll need to also be sure to get everything that is needed to run your machine.
You can search for:
Make Model power cord
and see what comes up. Then compare the description/picture with your machine.
https://www.sewingpartsonline.com/viking-300-sewing-machine-parts.aspx
Feb 16, 2018 | Husqvarna Sewing Machines
I bought a janome 300e .ive purchased designs and have downloaded to my computer. I've transferred them to a disk. . On the computer it says that the designs were transferred.
Check that the designs are not in a folder on the disk. Your sewing machine may need to open that folder before the designs can be found.
Also, check to make sure the OS software on your computer is compatible with your sewing machine. Some sewing machines use Windows 7 or even earlier versions, whereas most new computers now have Windows 8 or 10.
Feb 09, 2017 | Janome Sewing Machines
I purchased this Singer only days ago, today is my first use.Although my machine worked earlier, now my bobbin isn't feeding properly and Is not stitching.
Install a brand new needle.
Remove all the thread from the machine and rethread from the beginning. Be sure to ALWAYS raise the presser foot when threading the upper thread so the thread will seat in the tension disk. Verify that the thread path is correct and that the bobbin case is threaded correctly. Check the upper tension setting--normally, it would work best around the midway point.
If there are still issues, you may have a defective machine.
Feb 09, 2017 | Singer Sewing Machines
My sewing machine will not pick up the bobbin thread. I have rethreaded both and still no luck. I was sewing earlier today and have no idea what went wrong. I have changed the needle
make sure the bobbin is spinning in the correct direction, and that you are turning the hand wheel in the correct direction.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Singer Sewing Machines
The handwheel will not even turn
open and take everything off and turn on then turn off and put everything back in and see what happens.
Sep 06, 2012 | Brother PS-1250 Pacesetter
I have a singer confidence 7470 and I have had it since March. I last used it on Monday and it was working just fine. Today I plugged it in and it won't turn on. I don't know what to do..
It should be under warranty, take it to where you bought it, if after trying a different electrical outlet, and making sure that the cord is plugged in correctly, it still does not turn on, You could have a defective cord.
Apr 20, 2011 | SINGER 7470 Sewing Machine
Just purchased this model today and it has no blind hem foot. Instruction manual telle me I need to purchase from local dealer. Can this be odered on line? Manual quotes number 006812008 is this...
You can order from Singer at 1-800-4singer or ebay. On ebay they start at about $14 + $2 for shipping. Just put in "blind hem foot for Singer and you will see a variety of them. Take your pick. I don't know what Singer charges. JoAnn fabrics may carry them or a sewing machine retailer but anyway you do it, it is not expensive. Just remember that you have a low shank machine. Good luck and happy sewing.
Nov 12, 2010 | Singer 8280 Mechanical Sewing Machine
Hello i bought WHITE SEWING MACHINE MODEL 3900F DONOT HAVE A CORD FOR IT--OR EVEN KNOW MACHINE WORKS SO I HAVE NOT THE FOOT CORD OR POWER CORD TO PLUG MACHINE IN--THERE IS A 3 PRONG TO MACHINE---THREE...
Search for:
Make Model parts
You can probably find one (perhaps sites like eBay) where there are generic parts. Just be sure to make sure the plug on the machine matches the plug on the cord you purchase. There are multiple shapes and designs of plugs available, so compare the pictures with your machine.
Feb 28, 2018 | White Sewing Sewing Machines
Sewing machine is jamming
The UPPER thread is not threaded through the machine correctly.
Feb 11, 2010 | Kenmore 11101 Mechanical Sewing Machine
White Sewing 2200 Multi-Tasker Logo
51 people viewed this question
Top White Sewing Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
radcal
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
