Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Posted on Mar 18, 2010
Get Err CF in view finder and cannot take pictures
I have a Canon EOS Digital Camera. Took lots of pictures over the past few days and when I tried to upload them to the computer it tells me the card is empty and I get an error message "err CF ( 0) in the LCD display. It won't let me take pictures and the error message also appears at the bottom in the view finder.
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
2579
Points
36
Did you try removing the memory card and making sure its not locked?
ERR CF and ERR 99
there is cf unit faulty might pins are bent or damage and could be come out from board that why giving cf error and err99
Have canon 350d, yesterday came up with CF err. Tried 2 diffrent cards, same thing. Friend tried my CF cards worked fine in her camera. Please help
Please look inside your cardholder and you have seen a lot of small pins.
If one or more of the pins are bending or missing it gives an error on the camera display
regards Rob NL
6helpful
2answers
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
1helpful
Error 99 in Canon EOS 350 D
Try the following diagnosis steps, in this exact order. This will isolate the cause of the issue: -
3answers
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Canon camera problem
Can you read the card in your camera?
If you cannot read the card in the camera...wow and ouch.
Try to get the card to a friend or someone who can read the CF.
Then see if they can read the card.
Hate to say it, but with an error like that, it may mean that the CF card is not working.
Are you trying to read the CF card on a reader on the computer?
Try your usb cable to the computer instead of the reader.
It is possible that the driver has become corrupted for the reader on the computer. Try the above, see what happens.
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
