Question about Gateway Computers & Internet
I have a Realtek HD audio driver on my Windows XP Media Center Edition version 2002 with SP3. I can listen to anything online and offline but I can't record anything using my Wave Pad sound editor or Acoustic Labs Multi-track recorder or any music editing software. I opened up my device manager and there is a message stating that another sound driver has disabled my Microsoft WNMM WNM Audio Compatbility Driver. I do not have the windows xp cd. I don't believe that there is anything wrong with my sound card just can't record for some reason. need help please.....
Posted by c_hopwood on
Anonymous
    New Friend:
  • 174 Answers
Open your control panel.
Click on Sounds and Audio Devices with the control panel in classic mode.
Click on the Audio tab.
Is Realtek HD Audio Input Device listed as the default device under Sound recording?
If not, select that from the drop down list and click Apply/OK.
Posted on Mar 18, 2010
woozie38
  • 608 Answers
Make sure your input and out put device is set to Realtek HD Audio Input; & Realtek HD Audio output, respectively, in sound and audio device settings.(under voice tab) Next ensure there are no ticks in the boxes muting your mic, & finally make sure you volume sliders are about half way up.
My realtek audio drive has been not installing.........
can u tell me wt operating u r using n what is ur model no or configuration of ur desktop or laptop...!
Feb 26, 2011 | Computers & Internet
Unable to install audio driver Realtak HD
The latest version of realtek would need SP3.. but then uninstall it and reinstall it againg.. it should work. Download the realtek software here... http://www.brothersoft.com/realtek-high-definition-audio-driver-65158.html
thanks for rating Good luck
Jan 13, 2011 | Microsoft Windows XP Professional With...
How to solve ploblem it's error number 0xe0000227 realtek
here goes amed
There is really only 1 way to install the Realtek HD Audio drivers properly. No matter what all other forums say. Service Pack 3 is the main culprit as the drivers see that its above SP2 and dont install. I personally face this situation and was really distressed because it looked like either i will have to reinstall Windows Xp or have my new supercool and super monster computer without sound. Imagine having a monster PC with a motherboard with HD Audio and your driver doesnt install.
Both scenarios were something which i would never have approved of. Anyway so i Googled. I got 10s of solutions but most didnt work. Only 1 worked and i will put it here hoping that Google dear will catch it and people who face this problem installing the Realtek HD Audio 0xE000027.
  1. First Step is to make sure all instances Realtek Audio and its associative softwares are uninstalled from add remove programs and device manager. This includes Intel High Definition audio.
  2. On your PC change the CSDVersion registry key to Windows XP SP2:
    HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=200
This problem arises as the patch thinks that SP3 includes a better version of the patch itself and hence doesn’t install itself.
3. Download the latest drivers from the Intel website, navigate to the KB888111 patch.
4. But before installing the patch, goto your device manager and disable the UAA. Now uninstall the UAA.
5. Install your patch now.
6. Install the Realtek drivers now and things should work.
7. Change the SP version to 300 again.
If it didnt work, try once again. Hopefully Error 0xE000027 is fixed now.
Jun 05, 2010 | Microsoft Windows XP Professional With...
Audio Problem
http://intel.driversdown.com/Intel-drivers/Intel-Desktop-Board-D945GCNL-HD-Audio-Controller-5605-Windows-Vista(32-64)-XP(32-64)-2000_77686.shtml
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Apr 23, 2009 | Intel D945GCL Motherboard
Sound drivers for windows 2002 sp3 for 945 intel s
first u need a winows update called high defintion audio driver package for winows version u r using ... install that first and update ur high defintion audio device using realtek driver
Mar 30, 2009 | Intel Motherboard
Pleaseeeeeeeeeeeeee
The driver should be on the motherboard CD. If not go to the website for the MB or Realtek or try drivers . com
It might be on the server 2003 disk so try a reinstall of the driver ONLY from that CD.
Sep 22, 2008 | Biostar P4M890-M7 Motherboard
Xp audio driver for fujitsu amilo
Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
[UnSupported] Windows XP Media Center Edition (WHQL)
Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
Jul 03, 2008 | Computers & Internet
Hello. Simply need XP drivers for e-machine model W4682 so XP can be reloaded from scratch. Vendor site is useless. Any info would be helpful.
here you go this should be all your drivers.
Modem Description Riesling Modem Driver File Type Original Driver Version 7.4.5.50 Operating System Windows XP Driver File Download (1.44 MB)
Chipset Description Intel Chipset Driver File Type Original Driver Version 5.0.2.1003 Operating System Windows XP Driver File Download (2.65 MB)
Video Description Intel 845GV Video Driver File Type Original Driver Version 6.14.10.3722 Operating System Windows XP Driver File Download (7.15 MB)
Media Reader Description Universal 8-in-2 Media Reader Software File Type Original Driver Version 1.08 Operating System Windows XP Driver File Download (4.40 MB)
Audio Description Realtek AC'97 Audio Driver File Type Original Driver Version 5.10.0.5320 Operating System Windows XP Driver File Download (16.70 MB)
Network Description RealTek Onboard LAN Driver File Type Original Driver Version 5.606.811.2003 Operating System Windows XP Read Me File Download Driver File Download (2.20 MB)
hope this helps if this isnt the correct series its the w-468 series drivers
Jun 18, 2008 | E-Machines Computers & Internet
Computers & Internet Logo
290 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
