Whirlpool Duet GHW9150P Front Load Washer Logo
Question about Whirlpool Duet GHW9150P Front Load Washer
F 14 error code on whirlpool duet washing maching. repair man say it needs ccu. How can I replace it and where can I purchase the part? Can this error code mean anything other than bad ccu?
Posted by dawnnic on
Anonymous
  • 218 Answers
Remove the bottom front panel 2-3 screws at the very bottom. Inside there should be a tech sheet that will explain error codes and how to trouble shoot them on your specific machine. Replacing the CCU is not that hard but getting to it is tricky. See following link to video on repairing duet http://www.rakerappliancerepair.com/ApplianceLibrary/Washers/WashersLibrary.aspx
Posted on Mar 17, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/14 error code on...
The error F/14 is shown on the display due to EEPROM Error detected in the washing machine.
In this problem check the Central Control Unit (CCU) the ccu is not receiving the proper data from the EEPROM board in the machine. This will Help. Good Luck.
on Mar 11, 2010 • Washing Machines
1helpful
How do i unlock the controls on my duet Whirlpool washing machine
do you see error code F/14 if so switch the machine power off or unplug it from the wall socket for 2 minuets see below,
EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM onboard the
CCU. If there is an error reading this data it will cause this error.
Potential Causes
• A power glitch may cause this error. Try unplugging the Unit for two minutes to
see if that fixes the error.
• Check CCU.
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
F11 error - Whirlpool Duet washer
F11 Serial communication error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2P3BOEFKI
you'll need to call someone in on this one,boards are very expensive and like it says it names both the ccu and mcu boards or the motor,if you call say whirlpool they might give you the part but you pay for labor and they will have the boards on the truck,the guy will replace one board at a time to see what one is bad,not like the older machines that you can check the parts with a meter.good luck
Whirlpool Duet Washing Maching fault code F70
Hi
Thanks for using FixYa. Error F70 is a communication error between the Central control unit (CCU) and the user interface. To start with you’ll need to check continuity of the user interface and then check the wire harness connecting the user interface & central control unit. If the drum is not moving then central control unit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
2helpful
2answers
F14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
1helpful
Whirlpool Duet washer GIVES ME f11 ERROR CODE
The F11 error code means that there is a communication error between the CCU (central control unit) and the MCU (Motor Control Unit) and it is not sending the message correctly. Check the wire harness connectors to the MCU and the CCU. Check the drive system for any worn or failed components. Check the MCU and the CCU and the motor. You may need a qualified repair technician for this one.
1helpful
2answers
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Whirlpool duet washer flashing F-11
"F11" is a Serial Communications error. This is usually an indication of a failed Central Control Unit (CCU). This is the main computer for the washer and is located directly behind the wash tub. The wiring harness can also cause the error, but it is not a common problem. Typically, the CCU fails.
In order to access, you will need to remove the top panel of the washer. Ironically, searspartsdirect.com has the CCU listed for about $200. It's listed under the "Control Panel Parts" as item number 15 (part #8182695). Repairclinic.com carries the same part as item number 1776592 and lists it for around $162. This is a simple repair that the average Do-It-Yourselfer can accomplish on their own. If you wish to pursue the cheaper option, post back and let me know. I can give you additional advice on how to install a new CCU.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
See? You might have saved yourself about $200 just by reading this. I hope this helps you.
PS If you have a service plan or extended warranty this repair would be covered.
Marvin
Marvin
Mike
