Technics SL-1200 Turntable Logo
Anonymous Posted on Mar 17, 2010
My brand new Technics 1200 MK2 sounds wobbly when I play it, and the lights dim in and out...as if the power wasn't flowing evenly. This is the 2nd one I bought. The same issue happened with the 1st one, so I took it back because I thought it was defective, and purchased a new one from another store. Same issue.
  • Anonymous Mar 18, 2010
Anonymous
Level 3:
Genius:
  • Master 1,043 Answers
  • Posted on Mar 18, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1043
Questions
Helped
286244
Points
3188
It sounds like you were the unfortunate recipient of two bad turntables that must have come from the same defective manufacturer's run. The symptoms you describe are usually caused by issues with both the power supply circuit and the pitch control circuit. The only other thing that is possible is the power supply you are using is not giving you clean power. If you haven't already done so try and plug the turntable into a different power receptacle and see if it makes a difference. Otherwise the only recourse you have is to return the unit and try another one.
Shehu Pro
Level 3:
  • Master 1,284 Answers
  • Posted on Mar 17, 2010
Shehu Pro
Master
Level 3:
Answers
1284
Questions
Helped
334444
Points
3802
Hi, please don't tamper with it so as to not loss your warranty on the product. I sounds to me as a factory fault problem. My advice to you is to take it back to the store you got it from and request for another one but make sure you test it in the store before you take it home and if you are not satisfied, you request back for your money..
Take care
  • Shehu Pro
    Shehu Pro Mar 23, 2010
    Thanks for using Fixya....
1 Related Answer
STYLUSCITY
Styluscity
  • 271 Answers
  • Posted on Sep 13, 2010
SOURCE: SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
[email protected]
Need to replace power cord - Technics 1200 MK2
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
1helpful
[email protected]
1helpful
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
1helpful
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
2answers
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
