Question about RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
Tv LCD RCA model L32WD22 what ic replacement can I use as Green Chip number EA1532? I was try with TEA1507 but i don´t know if the pins are electrically same because I have not esquematic of the power supply. Number of the power supply is ADPC24200T2P. Thanks for your help technicians friends.
Posted by Joaquin Hernandez on
Robert Billyard
    Sergeant:
    Champion:
  • 277 Answers
Servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Posted on Jul 21, 2010
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
HOW TO GET AN USER MANAUL FOR A RCA MODEL L32WD22 TV
I suggest you try the support section of the manufacturer's website where user manuals are often available for free download.
Feb 11, 2015 | RCA Televison & Video
I have no remote for an rca l32wd22 hdtv lcd tv and cannot find the inputs to change to HDMI?
Unfortunately, the L32WD22 doesn't have an Input button on the front panel of the TV. You need a remote control that matches the Input code for the remote. Here's one link to a remote that should work: http://remotes.com/store/rca/l32wd22.html . Other universal remotes may work if you find the correct code if the remote has an Input or Source button.
I hope this helps.
Apr 16, 2013 | RCA L32WD22 32 in. LCD HDTV
When i turn my 32'' rca flat screen on the red light is flashing but it would not come on ,what is causing that to happen ?
Power Supply problem, had the same problem, could not find a Power Supply board replacement even on ebay. They had a capacitor replacement kit, here on ebay http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Used that, and it worked.
Dec 11, 2011 | RCA L32WD22 32 in. LCD HDTV
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a RCA L32WD22 Green power light comes on but there is no picture or sound. This happened suddenly and about 2 weeks after the warranty expired. We can not find anyone that even works on a RCA around...
Hi Rachel,
Take your unit to a Sevice Center and ask them to fix it. They won't be able to because there are no service manuals. They will tell you they can't fix it.Make sure they do a Work Order. You should have this order or a copy of it, then you call 1-877-297-8391 and get youself a new tv
Mar 02, 2010 | RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
tnbanderson,
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Feb 03, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
I have an rca tv and vertical lines show up when i power the tv on model # is L32WD22
Tumble9827
Pls take your Tv to a Service Centre nrear you. Ask them to repair, and if they say they can't... Get that in writting on a Work Order,
Then call 1-877-297-8391
Dec 24, 2009 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 32 in. LCD HDTV Logo
442 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
