Dishwashers Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to locate any info on a model 10505 se # 982410041588
Anonymous
Level 3:
  • Asko Master 2,605 Answers
  • Posted on Mar 18, 2010
Anonymous
Asko Master
Level 3:
Answers
2605
Questions
0
Helped
1119173
Points
11111
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
1helpful
2016 Hyundai Accent SE. TCM location please?
Question edited for clarity.
Question moved to model category.
From what I gather from this video, it is a combined module ECM/TCM sharing the same box ECM on left and TCM on the right. There is a diagram showing it as well.
https://www.google.com/search?q=2016+Hyundai+Accent+SE.+TCM+location
https://www.2carpros.com/questions/2009-hyundai-elantra-tcm-location
Where is the location of the fuse for left low beam headlight? The car I have is a 2014 VW Jetta SE model, 1.8 liter engine. Thanks, - Bill
Hello Bill,
How bout year--make--model? If there is a fuse it should be in fuse box? Sometimes the fuse box cover has a legend that tells you which fuse does what? Your owners manual may have this info?
My database only covers vehicles sold in the US.
Microwave beeps and with each beep a 6comes up on display, and the START under the numbers flashes, but I am unable to press any buttons to clear it. Also sometimes I can open the door and press the...
You didn't mention your brand or model number, so I can only give you a general response.
It sounds like a shorting membrane keypad.
On Samsung's, they will show the error code "SE".
For detailed do it yourself info and/or an estimate, please post a new FixYa help request and include the model, or contact me here with that info.
1helpful
I have an Asko 10505 and have a leak in (I believe) the mixing valve. I need to see a parts diagram to know what to order. can you provide one? thanks
Hello, Welcome to FixYa. If you want to email me at [email protected] I can send the info you are requesting this evening...possible by AM tomorrow at the latest. Keep me posted on your progress or what you find. Good luck. Regards, Macmarkus :)
5helpful
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
4helpful
4answers
How can I upgrade my sony ericsson w910i firmware? My software version is 1200-9123 R1FA035 080527. Everytime I want to open the games or application in the entertainment menu, it says "Operation Failed"....
Hi!
First of all, try to back up your info on your phone, i.e. save all your contacts to your SIM card, download SE PC Suite 4.0.10.00 from SE website, download MyPhoneExplorer 1.7.2 from Majorgeeks (all latest versions), and backup all info - rather 2 or 3 places than losing everthing! Download Update Service from SE website - follow instructions on screen. Even if you have the same / latest version firmware, re-install it. It solved all my problems - some same as yours.
Good luck. I now enjoy my SE W910i more than I did any other phone before.
Eben
Error code
found sensor inside oven no continuity am ordering new sensor should fix problem
Jan 08, 2009 • Ovens
1helpful
2answers
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
2answers
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
