When i put my mercury 150 hp outboard into gear it hits really hard. Why ? It happens in forward and reverse.
Tickover should be around 1000 rpm then when in gear about 700 to 800 rpm but try as little as possible so engine is happy not to stall when in lake ! depends what pitch prop used also , bigger the pitch more drag ! dont adjust the cable , adjust the throttle stop on the carbs !
Posted on May 30, 2014
See if you can turn down the base idle some. Then check your gear lube, sometimes you can get an airpocket and the top end is dry. Last, if still not fixed, see if you can adjust the cables so that the throttle RPM changes after the gears do.
You want a little lag in the throttle so you don't take out a dock when coming onshore.
Posted on Mar 17, 2010
Jun 13, 2018 | Mercury Boating
Sep 28, 2015 | Boating
Sep 22, 2015 | Boating
Sep 27, 2012 | Boating
Jul 06, 2012 | Boating
Jul 23, 2009 | 2004 Mercury Mariner
Apr 15, 2009 | Sport & Outdoor - Others
381 people viewed this question
