This is a mechanical error - it need to be torn apart and re-assemble the tape carriage to the transport. Do not force anything to avoid further damage. There can also be a bad sensor.
That error means that something is out of alignment or stuck in the tape mechanism. You have two options: to have the camera inspected and repaired, OR if you don't want to do that and feel you don't have anything to lose do this: Remove the tape. Close the tape door completely. Close the LCD. Turn the camera off. Remove the battery. Give the camera a good firm smack or two on each side with the palm of your hand. Power the camera up and try the tape again.
It sounds crazy, but doing that can possibly help unjam whatever mechanism is locked up. This has worked for many people. Hopefully it will take care of your situation too.
Hi, This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment Thanks for using fixya.
Hi there. Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
