ASUS P5VD2-MX SE Motherboard Logo
Posted on Mar 17, 2010
Not beep - ASUS P5VD2-MX SE Motherboard
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Mar 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
7675
Points
96
NO beep its depends on the condition.
with out RAM it means mother board foulty...
with RAM no beep sound it means replace the RAM. ok if Same problem Accure means mother Foulty.
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 • Computers & Internet
tip
Computer error beep codes
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
you can now simply analyze if what is the problem of your computer...
on Feb 13, 2010 • Computers & Internet
1helpful
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
6helpful
3answers
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
2helpful
2answers
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Same here repeat of all other posts!!!! Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep Beep...
Code F1 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
3helpful
2answers
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
