Question about Home
I have a pioneer shower valve that has pressure problem
I have a pioneer shower valve that has pressure balancing. I would like hotter water but as it approaches the maximum setting (the temp adjust screw is missing)water just suddenly shuts off. I have removed the handle and plate and there are three adjustment screws on the valve itself. Any ideas?
Anonymous
    Scholar:
  • 86 Answers
The way anti-scald valves work is there is a slide tube inside the faucet which requires pressure from both hot and cold or else it will cut off the flow. As for temperature adjust I do not believe there is an adjustment screw but more so there are these white plastic toothed stop rings which prevent the handle from turning 360 degrees. When your adjust the stop ring, it adjusts how much hot water is allowed to mix with the cold water. My wife likes her showers a lot hotter than I, so I gave a good allowance with the stop ring. The "adjustment screws" which you are viewing are not for adjustment of temperature, they are remote cut-off screws to stop the water entirely to change the washers in the unit if needed. SO open those all the way and leave them open. Think of them as not having to go all the way into the basement to shut off the water supply just to change a few washers.
Posted on Mar 20, 2010
Testimonial: "Thank you exHandyman.... it worked "
I have a moen shower faucet where the water mixture keeps getting hotter with very little cold coming through. the temp must be set nearly all the way to cold to prevent scalding.
Sounds like a pressure-balance shower valve. The pressure balance cylinder is stuck. With water off, remove knob and trim plate. Remove pressure balance cylinder (horizontal). May be hard to get out. Use emory paper to clean up cylinder and smooth it so it moves freely. Reassemble and you'll be happy.
May 28, 2017 | Moen Home
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
May 18, 2014 | Danze Home
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Low shower pressure
  1. Is there a water saving feature/washer ?
  2. Was there good pressure before ?
  3. Is there an adjustment at the control valve for how much hot/cold water is being balanced ?
  4. Any debris stuck in valve ?
Aug 11, 2010 | RTO Symmons Deluxe Temptrol pressure...
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
I am getting to much hot water and no cold water in my shower valve
will depend on the faucet but sounds like the pressure balancing piece is frozen up....not allowing it to do its job regulating the flow of hot and cold.
Dec 04, 2009 | Pioneer Plumbing
Water not hot at the Symmons Safety Mix valve. Had plenty of hot water before I installed a new hot water heater. Now, it's not as hot. I turned up the temperature to about 130 degrees. Sometimes it is...
There might have been some sediment that came thru the water line after changing the water heater and got into the mixer valve. You may need to shut off the water and clean out the mixer valve assembly.
Oct 27, 2009 | RTO Symmons Deluxe Temptrol pressure...
Shower gets hotter or colder when toilet is flushed.
This is typical for an installation without a balanced valve/anti-scald valve on the shower.
If you are using manual on/off valves on the shower, about the only way to fix this is to install the device mentioned in the previous paragraph.
May 03, 2009 | Rheem Tankless Hot Water Heater...
Installed a new oak brook collection tub and shower faucet and no water comes out.
You may have to disassymble the faucet to see if there is something that is stuck in there or that the assymbly internally is stuck in the closed position.
Mar 19, 2009 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Home Logo
671 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
