HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pump motor stalled - HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Anonymous
Level 2:
New Friend:
  • Expert 100 Answers
  • Posted on Mar 17, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
100
Questions
Helped
25027
Points
235
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet. 4. Check for the functionality.
My floater in my fuel pump was not working , also it would stall on me , so I changed it , but I didnt changed the fuel filter and its doing the same thing
Stall at highers speeds, yes the fuel filter. I replace them with every pump. Parts stores don't warranty the pump without a new filter. If it stalls at idle, then the air filter, vacuum lines, clean the throttle body and idle air control motor.
The motor keeps stalling. works for a short time & fan stops
Seem like the motor overheating and the motor protector make the pump stop,
Check if there is any physical damage on it,
Is it a very old pump?
1helpful
2answers
Stalls when coming to a stop
Mine stalled when I stopped and it was the Idle Speed Motor. If it only stalls when you stop, I would check that before messing with the fuel filter or pump.
1helpful
Pump motor stalled
If within warranty then call 1 800 474 6836 (toll free) and get it replaced through HP.
If it is OOW then you will get an upgrade.
4helpful
Error Message: Pump Motor Stalled. Please advise
Try partial reset and semi full reset of the printer, this is error message is a hardware error, if the issue is still not resolved contact HP, they would replace the printer if it is under warranty.
1helpful
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 • Boating
'87 300ZX(NON-TURBO) STALLS OUT/BOOGS DOWN
overhaul of carb needed, check the vaccum advancer for wear n tear, rapace f necessary fo
1helpful
Motor stalls
 Check the engine coolant sensor and idle control valve, if it  stalls when pushing the brake pedal check the ground in the trunk ant left bottom corner.  Tail lights and fuel pump share the same ground.
3helpful
Builds up to much pressure in hose and stalls engine
Sounds like the unloader is not working. try replacing it and see if that helps.
k24674
Grand Canyon Tech
Grand Canyon Tech
