Question about Onkyo TX-SR504 Receiver
How do I adjust the balance of the speakers? One
How do I adjust the balance of the speakers? One channel doesn't seem to work at all..
electroman
    Genius:
  • 1,039 Answers
Press setup on front. press speaker level control. use left and rt up and down buttons to select speaker and set levels. hit return to go back of setup to get out.
Posted on Mar 26, 2010
Testimonial: "Thanks much. Everything works fine now."
One speaker channel not working
Hello
You haven't given any details about your Denon amp, such as Model number. Yet I posts this solution. Check the speaker of the defective channel, by using a multimeter. Check the wire that connects to that speaker from amp. If both are Ok, the defect is with the amp itself. Just check whethere 'balance' control of the amp is set to extreme left or right. If it seems to be at one extreme end, make adjust it to the center position.
If all are OK and still you do not get any sound from one channel, the set need repair. OK.
Jan 22, 2012 | Denon Audio Players & Recorders
I can not figure out how to adjust the balance on my speakers. It seems that one speaker in louder than the other. I cant find my manual and i've been tinkering with the receiver with no avail.
Tinkering won't work. HT510??? Not HTR510? Maybe that's what you meant.
All AVR's have settings for individual speaker channel levels and distances from the listening position.
http://filedepot.onkyousa.com/Files/own_manuals/HT-R510.pdf
Jul 11, 2011 | Onkyo HT510 Receiver
How do you balance sound between two speakers. Where is the balance control? JVC RX5000v
On the front panel ONLY:
1. Press ADJUST so that the MULTI
CURSOR up/down buttons work for
adjusting the sound.
2. Press MULTI CURSOR up/down
repeatedly until "BALANCE"
appears on the display.
3. Press MULTI CURSOR left/right to
adjust the balance.
• Pressing left decreases the right channel
output.
• Pressing right decreases the left channel
output.
please rate my solution.
Jul 04, 2011 | JVC RX-5000V 5.1 Channels Receiver
Sound seems to coming from only one of my front speakers(left side). what am i missing? I can't seem to find a balance setting on the menu
Traditional Balance Controls are gone with the dinosaurs of stereo audio equipment.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Adcom-GFR-700-Receivers-manual/id/582dj599/t/2/
You may just have a speaker or speaker wire loose/failing. Swap them to isolate to an internal or external failure.
There isn't enough adjustment in the setup to make any channel completely silent.
Use test tones to diagnose it. Page 36.
Apr 25, 2011 | Adcom GFR-700 Receiver
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Not able to figure out how to turn off the outside speakers.
This receiver has four channels. Typically in a car that would be two front and two rear speakers. I would guess that the outside speakers are the rear channels and the inside speakers are on the front channels. Look in the manual for front to rear balance adjustment, and place the balance on front. Hopefully, the inside speakers will work, and the outside speakers will not.
If this does not work, get back to me and we'll figure out other possible solutions.
Jul 30, 2009 | Dual XD6210 CD Player
Channel Problem
It could be a bad balance control potentiometer or just broken/cold soldering joints due to the age. Bring it in a repair shop. Thanks. ebcelectronics
Apr 06, 2009 | Audio Players & Recorders
Onkyo TX-SR504 Receiver Logo
1,228 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
