Question about Kettler Caterpillar Excavator
Caterpillar 924F has no power to all four front facing work lamps, the switch is working OK, power in and out.
Posted by mobileautoel on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Do you have power available at the harness deutch plug connector running out through the cab-it should split into two cables, if no power here it sounds like a relay, find the working light relay and swap it with another to see if this solves your problem
Posted on Apr 20, 2010
No front headlamps. Have park lights
check that there is power to the relay from the switch or replace the head light module.
Jan 10, 2014 | GMC Cars & Trucks
Parklights not working front and rear
have you started with the basics check the fuses the head lights and the parking lights are different fuses
Sep 30, 2012 | Ford F-150 Cars & Trucks
None of the blinkers work on my 1996 dodge stratus, all bulbs are good as the park lights and flashers work. I have three dead ports in fusebox under hood.
Guessed it's a V6. Trying to sort this out. If setting the headlamp switch to PARK turns on the park filaments of the front park/turn signal lamp and the tail filaments of the rear tail/stop lamps and the separate tail lamps, the park light circuit is good. If 20A fuse 6 in the power distribution center is OK, the combination flasher in the multifunction switch is receiving power. Power is directed to the turn signal lamps by operation of the turn signal/hazard warning switch. If the turn signals are not flashing, the combination switch may have failed or the turn signal flasher part of the combination flasher may have failed. Finally, the hazard warning switch causes the turn signal elements of the front combination park/turn signal lamps and the rear turn lamps to flash.
Sep 14, 2012 | 1996 Dodge Stratus
Doing research for a law firm regarding an accident involving a Caterpillar 55 Challenger. Question is if the Challenger had it's four-way flashers on, would the turn signal still work?
Four way flashers and turn signals are typically on the same circuit. If this is the case than no the turn signals would not work since the turn signal switch has been bypassed by the four way flasher.
I wiring diagram for this model would confirm whether or not it was wired in the above fashion.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 19, 2012 | Cars & Trucks
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Green blinking light, power comes on but no light no fan, nothing else just green blinking light on front, tried system reset and it did not work
Problems with the DM assembly will cause perpetual "boot up" or blinking sequence, but if this is the case the TV never actually turns on. If you are able to turn power on after boot-up (which should only occur at plug in), then suspect lamp or ballast errors. The lamp is simple to inspect yourself, just don't touch the face of the bulb. If that's ok, you'll need a qualified service tech.
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57734 57" HDTV
I havea 1995 Ford Fiesta and the indictor lamps(front and rear) only work on the right hand side, if you try to indicator to turn left you just get a ticking from behind the instrument panel and neither...
Try the hazard lights to check if all four lights flash, if not then check the bulbs. If the bulbs are ok check the contacts and the connections. if all all these are ok the problem could be the indicator switch. The flasher unit is fitted in the circuit before the indicator switch, that is why it operated although the lights might not.
Jan 17, 2011 | Ford Fiesta Cars & Trucks
Need a fuse box diagram to wire in fog lights
Fog lamps are installed on the front bumper. The switch is located to the left of the steering column on the dash panel. The fog lamps are turned off by the circuit relay when the high beam driving lamps are turned on. The circuit relay is located on the right front wheelhouse panel near the blower motor.
Good luck, and remember rated this help.
Removal & InstallationFog Lamp Element
See Figure 1
Fig. 1: Exploded view of a fog lamp assembly
  1. Remove the lamp stone shields, the four bezel attaching screws, and the bezel.
  2. Remove the reflector assembly from the lamp body.
  3. Remove the bulb holder from the assembly. Remove the element from the bulb.
DO NOT handle elements with your bare hands, always handle with a clean cloth. Oil from your hands will cause the element to fail.
  1. Installation is the reverse of removal.
Fog Lamp Switch
The fog lamp switch is removed and installed by simply prying the switch from the instrument panel and unplugging the electrical connector.
FOGLAMP BEAM ADJUSTMENT
  1. Position the vehicle on a level surface, facing a wall approximately 25 feet away. Remove the lamp stone shields and loosen the adjustment nuts.
  2. Turn the fog lamps ON and adjust as follows:
    1. Distance between the light beam centers should be equal to the distance between the lamp assemblies on the bumper.
    2. Height of the light beams on the wall should be 4 inches less than the center of the lamp assemblies when mounted on the bumper.
  3. Install all previously removed items after turning OFF the fog lamps.
1995 Cherokee Chassis Schematic
www.autozone.com
Aug 11, 2009 | 1995 Jeep Cherokee
I recently purchased a EV P3000 amp not working.
get all components from (rs components).take fuses down there and there let u know the right ones.mapdata?cxw3pxedhfvx-f8gdwxajgjiuqfsakdckaecygeczw4
Aug 03, 2009 | Audio Players & Recorders
My left indicator isnt working,the rest are though
need more info ??does it work with hazzards on ??all four lights?'
Jun 14, 2009 | 1999 Volkswagen Passat
Kettler Caterpillar Excavator Logo
245 people viewed this question
Top Kettler Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Kettler Toy Expert? Answer questions, earn points and help others
