Question about HP Pavilion dv4000 Notebook
THe computer appears to be connected to the
MY new laptop appears to be connected to the internet and all the other computers are working well on this connection
At the moment each time Iwant to browsw a single page I have to isconnect it and then reconnect it, .
Eg ie gmail, I open up Gmail and by the time I have written the email and gone to press send, the internet doesnt work, even though it appears to be connected. I then have to disconnect and reconnect and then the problems starts again. A proper working connection only lasts for a few mins!!!!
Its doing my head in, is their some setting I need to change, its not my modem as all the other old laptops work fine!
  • 311 Answers
Hello
In this case please upgrde your internet explorer or try to install mozilla firefox and you can try.
when ever you face this issue check the ipaddrerss in command prompt start- run - cmd- ipconfig should get the valid ip[ address and run one command in cmd ie ipconfig /flushdns
and then try to access internet
delete all the temp files and cookies for internetr explorer
let me know the results
Posted on Mar 17, 2010
6ya staff
SOURCE:
I got a new Lenovo Y460p i7 2630 QM last week. Everything else appears to be working fine, but the laptop has issues with the wireless internet. Although, it works fine on LAN, and my other laptop connects...
On the front of the laptop, you will notice a switch. It turns the wireless on and off for airport security etc.. make sure it is on - pc icon with brackets on each side....good luck!
Jun 13, 2011 | Lenovo IdeaPad Y460p Laptop Computer -...
Tip
How To share a ADSL Connexion with 2 computers
Introduction
It is about sharing the ADSL connection from PC1
(Server) with PC2 (Client).
Assume that the connection to the Internet
configured correctly in the PC1.
* ) Hardware Requirements
A PC running Windows XP and equipped with a network card
(Server).
Internet access.
A second PC with a network adapter (client PC).
RJ45 crossover cable
*)Configuring Server Side
1. Assign an IP address
Click on Start / Control Panel / Network Connections
and Internet
Double click the Network Connections icon
get a new window
Click on the icon Local Area Connection with the right button
your mouse and select Properties. A new window appears
Double click on Internet Protocol (TCP / IP) a new window
appears
2. Share the connection.
Back in the Control Panel and select
Connections.
Then in the window that opens right click
your Remote Access (for example ADSL) and select
Properties option.
A new window appears:
Select the Advanced tab under Connection Sharing
Internet check Allow other network users to
connect through this computer's Internet connection and the
Establish a connection box Dial whenever
computer attempts to connect to internet and confirm by clicking
OK. A new window will open:
To Continue Click Here : .....More
on Jul 15, 2010 | Computers & Internet
Laptop doesnt connect to wireless internet (wireless card is fine
When you reformatted your HD, did you use IBM's method which utilizes a hidden partition? This results in a laptop which appears to be as if it just came from the store, like a brand new laptop.
This method sets up the computer in the exact way that IBM built it. And puts all devices in their proper configurations.
If you have not done too much yet, you might want to try that method right away and see if it doesn't make a big difference in the way your laptop works.
-a.
Feb 19, 2010 | IBM ThinkPad T42 Notebook
I can't find my local area connection...how can i can i get it?
may in service pack 2 there is no LAN but you have to reinstall to he your original service pack that you to contact dell and one more thing for you have to install drivers of connection or internet because your service pack2 has not installed drivers
Dec 16, 2009 | Dell Computers & Internet
Trouble setting up work laptop to use Internet thru home computer
Do you have any firewall installed on your computer?
If so, try disabling it. If it doesnt work, keep going.
does your modem have a green light on the "internet" or "activity" status? if not, you have a problem in your modem.
hope it helps.
Aug 07, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Internet connection
Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Jun 18, 2008 | Dell Inspiron E1505 Notebook
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Ive installed xp on my acer travelmate 4100 laptop
hello!
Apr 22, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Can´t access 192.168.1.1 (router admin page)
hello!
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
if this still didnot work, upgrade the firmware of your router
Apr 19, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
