Question about Pioneer DEH-1800 CD Player
Pioneer DEH-1800 how to set the clock
How do we set the clock
Posted by gaceug on
Dale Burns Sr.
  • 410 Answers
Hold SOURCE until the unit turns off.
Hold AUDIO until the clock appears Use the LEFT or RIGHT adjust
Posted on Mar 17, 2010
5 Related Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: pioneer cd radio deh-11 clock set
For most Pioneer single CD players, you can set the clock using the following steps:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Posted on Apr 11, 2008
Anonymous
  • 24 Answers
SOURCE: setting clock on my pioneer deh 1400
the radio must be turned off with the ignition key in the on position... then hold the function key for about 3 seconds if it doesnt have the function key try the audio or source button one of them will bring you to a menu, once in that menu use the func key to scroll though options until you see the clock flashing.. use the up down left right keys to adjust these different options...
Posted on Feb 21, 2008
Anonymous
SOURCE: pioneer
turn the HU off...hold down the source button for a couple of seconds and the screen will pop up with the time on it...easy to change from there with the "left, right, up, down" buttons surrounding the source button.
Posted on Aug 09, 2008
mikehumble
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
drsinister69
James Milzheimer
  • 2317 Answers
SOURCE: Set clock on car radio.
Here is a link to the owner's manual for the stereo which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1800.PDF
Posted on May 22, 2010
Testimonial: "Feedback was perfect. It solved my problem and answered even more as I read the manual. Thanks for the help. George Haggerty Jr."
May 22, 2010 | Pioneer DEH-1800 CD Player
Can't find how to set clock
Try page 10 of this link to your Pioneer DEH-1800 Owners Manual.
http://akamaipix.crutchfield.com/Manuals/130/130DEH1800.PDF
You will need to copy and paste the above link to your browser.
Mar 17, 2010 | Pioneer DEH-1800 CD Player
How to set clock
Not sure if you have tried this yet or not but try turning the radio off and then holding down one of the buttons for a couple secs to set the time. I have to set mine with the radio off and thought maybe you hadn't tried that...
Dec 13, 2009 | Pioneer DEH-1800 CD Player
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
Nov 10, 2009 | Pioneer DEH-1800 CD Player
Sterio is new to me and has no instruction how do you set the clock to it model # DEH-1800
hey mate try turning the head unit off then there should be a fnc (function) button while the unit is off hold this button in for 5sec should bring up a menu with date/time and other functions after the menu is up just press the function button normally to scroll thru the menu
Sep 23, 2009 | Pioneer DEH-1800 CD Player
Setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Apr 28, 2009 | Car Audio & Video
How do i set my clock on a pioneer mosfet 50x4 deh-1800
I have an Alpine CDE-7859 but I am unable to change the time setting; can you help me
Dec 28, 2007 | Car Audio & Video
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Nov 24, 2007 | Pioneer DEH-P2500 CD Player
Pioneer DEH-1800 CD Player Logo
807 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
