I have a 3 year-old Goodman compressor/heat pump. When the unit starts for the first 30 - 60 secs the noise it makes is an extremely loud rumble that can be heard 100 yards away. After the first minute - it is louder than it should be -- more like a whining noise. HVAC guy says -- motor is out of balance -- bad bearings -- says something must have fallen and hit a blade -- I see no evidence of that. $800 estimate to repair. Does Goodman have a history of this problem?
Without being there to see it and have only your description in front of me, it sounds like the fan blade could be out of balance.......but it sounds more like a loose fan blade hub. Most Goodman units offer a minimum 5 year parts warranty. The Labor warranty is questionable, but the installing contractor or the Goodman Distributor should be able to give you that information. Of course this would cover manufacturer problems and not physical damage. As far as a history of this problem with Goodman..........I've seen it with every brand. If there is a problem getting it under warranty, you might be able to purchase the blade yourself. Before replacing the fan blade, I recommend disconnecting the motor wires from the contactor, tape off the ends and remember exactly where they were attached.....then start the unit to see if the noise is still evident, if so, it's probably your compressor. I recommend a certified repairman....not the one that quoted you $800.00. If you hear only the compressor start up and not the loud noise you are discribing, then try replacing the blade first.
I hope you find this information to be very helpful to you. :-)
Testimonial: "good advice"
SOURCE: 3 year-old Goodman compressor/heat pump terribly loud @ start
I don't think this problem (btw I agree 'from a far distance' with the Hvac guy) is inherant to Goodman, after all the compressor (that is in the unit) is one that if found in other brands too.
Of course the compressor is under warranty so there's no charge for it - but - $800 to change out the compressor (and that's the proper fix) is a 'bit' high - you possibly could save a few bucks by getting some other estimates.
good luck!
