Question about Denon DRA-375RD Receiver
I'm convinced the fuse is blown in Denon Receiver, I'm having trouble locating it...where is it?
Posted by Brandon Roberts on
ABRsvcs
  • 4,234 Answers
There is a main fuse located either close to where the AC cord enters the unit or under a PC board attached to the transformer. In any case, it is unlikely that the fuse is the real problem. Is there a standby light at all or nothing at all? If there is a standby light, the fuse is fine. If the unit won't stay on or turn on, the problem could be a bad 5V supply or shorted outputs.
Please update this with any additional symptoms and I'll provide additional details.
Thanks,
Dan
Posted on Mar 16, 2010
Testimonial: "thank you, your right. The problem is definitely somewhere else."
  • irsinaz Dec 25, 2010
    My Denon receiver stopped working all together. almost 3 years old, but only in use for about 2 years. all of the sudden it just stopped. on standby lights, nothing. Also, I have no fuse veiwable on my receiver. What could be the problem?
Denon 4806
If the channel is blown and you have replaced the fuse your receiver needs a trip to the repair shop.
Aug 24, 2014 | Denon AVR-4800 Receiver
Denon DAR-395 sparks
You most likely have shorted output transistors. This will cause the fuse to blow, and usually burns up a couple resistors as well.
Apr 22, 2013 | Denon DRA-395 Receiver
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
My denon doesn't have any power when I plug it in, it doesn't make any sound, no lights come on. The outlet power strip does
if you have power on your ac outlets but your receiver is not responding i would try replacing any of the visible fuses that appear blown and one question did it have any issues at all leading to this failure? hope this is some form of support
Nov 17, 2010 | Denon AVR-1508 Receiver
I have a Denon receiver dra 545a that won't power on... how costly might it be to repair
Sounds like the power supply went out. Check inside to see if a fuse is blown. Replace it once (with the exact rating) and if it blows a second time, then you have something shorting out and can be costly to repair. DO NOT replace the fuse with a higher rating for it might cause a fire.
Oct 31, 2010 | Denon DRA-397
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
Denon AVR 3806 - No Power
open unit replace fuse....im sure u have blown fuse..
rate me fixed ok
Feb 14, 2008 | Denon AVR-3806 Receiver
Denon avr 1507 no power
look at power supply and see if blown fuses first and then check for any open resistors.
Sep 14, 2007 | Denon AVR-1507 Receiver
Denon DRA-375RD Receiver Logo
809 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
