1999 Cadillac Eldorado Logo
Anonymous Posted on Mar 16, 2010
Fan motor does not blow hot or cold air when turned on
When I set the climate control unit to either heat or cool the vehicle the fan motor does not seem to work. I can hear the vent doors under the dash open and or close but neither hot nor cold air comes out of the unit. I have a 1999 El Dorado with 66,000 miles
thanks for your help. Robert
Anonymous
Level 3:
  • Master 326 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
Answers
326
Questions
0
Helped
118818
Points
1084
Your fan motor is located on firewall behind engine towards middle of car under a cover gain acess turn fan on inside car lightly tap back of motor if fan starts running you have a bad fan motor i assume you have already checked your fuses
Testimonial: "Many thanks for the help."
1helpful
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
2answers
2004 chevy Impala my heater and my air conditioner wont blow air
start with using a meter to test for power start from fan back to switches need to check harness and connectors
Why wont my a/c or heater fan come on?
When the blower works only on the high setting its usually a bad blower resistor which is right near the blower motor. now you say it would always blow high regardless of the fan speed setting that would indicate probably the climate control unit or a connector problem somewhere. finally it not working at all may be the climate control unit or connection went bad even further. it might have a blown fuse or a bad blower motor in addition to the climate control unit or connector problem .check for power and ground at the blower motor. the power is supplied from fuses and may have a relay also. the ground is supplied from the climate control unit and goes through the resistor to control the fan speed. good luck
Cooling Fans coming on shortly after starting cold vehicle Ford Winstar 2001
climate control units in most cars use the ac system to regulate temp in the cab. the ac system requires a fan to pull air over the condensor on the front of the car. its normal for a fan to come on. unless you have a bad engine temp sending unit thats causing the engine cooling fan to come on improperly. try turning off the heat and ac and see if it still comes on.
5helpful
3answers
Would the heater control valve malfunctioning make the engine overheat blowing hot air out the heater one moment,then not blowing the hot air, temp gage spikes 225 plus. The motor takes awhile to heat up...
Heater control valve malfunction will not cause engine to overheat unless coolant is leaking externally...Overheating going down the road can be the result of a few different things...Partly clogged radiator...Insufficient air flow due to possible fan problem...External coolant leak...Make sure fans are operting properly and have cooling system pressure tested for leaks...Gaining and losing heat on the inside of the vehicle usually means system is low on coolant but you must find out where coolant is going
My heater fan turns on before the car has warmed up. It blows cold air? Any ideas why?
After warmup it still blows cold, or only when cold? Normally the fan will operate independently of engine temp except in some climate controlled vehicles. As long as it blows warm air after engine is at temp that's a good thing. the heater uses hot water from the engine. Obviously the heater can't be warm before the engine is. If it's cold after the engine is hot, there are vacuum controlled "motors" on top of the heater box under the dash that move doors that control heat. Either one of the control motors or one of the doors have stuck or failed. Many also have a control valve on one of the heater hoses under the hood as well. If the engine comes up to temp then the thermostat is good (should be at about 210f) Only remaining item is the core itself which may be internally or externally obstructed.
All this being said, if it's good when the engine is up to temp, leave it alone...it's fine.
2answers
Heater fan blows out cool air then car over heats then blows hot and cools the car back off. It does this over and over. Changed thermastat and waterpump already.
is your vehicle automat climate control ?
suspect the tempreture sensor in the vehicle is defective and is not giving a true reading of the relationship between the set tempreture and the true air tempreture.
No heat unless set at max temp. setting.
Hey Summers,, Are you running the A/C with the temperature set at max heat?? If yes. STOP... the A/C is for COLD air..As far as the fan speeds not working....you may have a fan switch that is going bad..(my vehicle is doing this!)..
3helpful
3answers
2002 kia sportage temp gauge runs hot while driving
Cheak to see that the coolant fan is operating with the A/C turned on. The fan has to work to help the engine stay cool and help the A/C. When you apply heat on the control it acts to reduce the coolant temp. You will have to get the coolant fan operation checked. This can be :fan motor, fan relay, temp sensor and computer. Good luck
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
