Question about Freezers
Drain keeps freezing over - Freezers
Posted by bcullen912 on
geoff hunter
  • 4,793 Answers
Normally when a drain keeps freezing over it is warm food being put into freezer/an air leak in door seals/drain hole could have some moss growing in it(really)or if kept in a garage,the poor thing is too cold.
Posted on Mar 24, 2010
Drain is clear but ice stilll forming in bottom of freezer
Use a steamer to blast the drain clear... sometimes you need to install what is called a heat probe that feeds into the drain tube to keep it from freezing over... Help Me Find My Model Number RepairClinic com
Oct 04, 2016 | Freezers
The drain keeps stopping up
Since there is no description of what type of freezer, I will talk generic. Most freezers have some sort of drain heater. Commercial walk-ins use them. 2 types: an insertion type that go inside the drain and another type that is wrapped around the outside of the drain and then wrapped with a foam type insulation call armaflex. hope this helps some.
Jul 28, 2017 | Freezers
The problem may be the freezer drain heater has failed, locate the drain inside of the freezer compartment and check to see if it is warm, if not you may need to replace the heater.
Jun 30, 2010 | Woods Upright Freezer MU07W
Install a drain heater available at most Appliance Parts Stores.
May 10, 2010 | Freezers
Have a ColdTech refrigerator/freezer that the drain line on the center back wall of unit, keeps freezing up. Have had the drain line heater replaced twice in less than two months. Suggestions?
I have a coldtech ice freezer 43SLG-L3-JF, the thermostat dial is blank, which way do I turn dial to lower the temp, clock or counter clockwise?
Apr 13, 2010 | Freezers
Kenmore Coldspot / Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
suprisingly simple,thread a thin piece of string down pipe then tie a button on each end works great for cleaning out drainpipe.....
Feb 28, 2010 | Freezers
Drain keep freezing up at entry point to the drain tube causing water to freeze from the drain top down to the bottom of the freezer. ( frozen waterfall!) Could the defrost heater be malfunctioning? i.e....
Not sure of your model number and manufacturer, but in some freezer there is a seperate drain heater that should stay on for the complete defrost time. (the defrost heater will shut off when the evap coil reaches a certain temp, and the rest of the defrost time only the drain heater is energized.) That would be the very first place that I would start. Hope this helps
Sep 20, 2009 | Freezers
Very thick ice collects in bottom of freezer
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
Jan 27, 2009 | Bosch Freezers
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
130 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
