Motorola Mobility RAZR V3 Logo
Anonymous Posted on Mar 16, 2010
I forgot my phone lock pin number, please help
I forgot my phone lock pin number and i saw where you guys told someone else to try pressing the menu button to get to the security codes. I did that and i got the phone open but it keeps running a serious of 4 and 3 numbers like its searching my phone but i still need to find my old phone lock pin so i can access my applications. Please help.
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Mar 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
16891
Points
155
Take it to your service provider. They should be able to fix your issue.No easey way around it, unless you don't mind losing ALL your info.
1helpful
I am trying to factory reset my Pend PNDPP44QC10WHT because I forgot my pin number but only Chinese comes up on the screen so I can't follow the steps to reset
Ok i take it you pressed vol down and power to get in to factory mode this is usually Chinese on some phones what you need to do is get into recovery to so that power off your phone hold vol up then press power and hold both until you are taken to a menu where you see the android guy being repaired there it should be in English if you see "no command" press the power button once and the options should pop up
Hope i helped :)
Jul 15, 2016 • Cell Phones
I have a samsung who forgot pasword, how to reset the pasword
There's good news and bad news. The good news is that you might well have forgotten that the default password on the Samsung phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.
First, here's what Samsung says about working with passwords on the Security
Use this menu to protect the phone against unauthorized use by managing the several access codes of your phone and SIM card.
Note: If you enter an incorrect PIN/PIN 2 three times in succession, the SIM card is blocked. To unblock it you need to enter your PUK/PUK2 (Personal Unblocking Key). The codes are supplied by your network operator.
PIN check
The 4-to-8-digit PIN (personal identification number) protects your SIM card against unauthorised use. When this feature is enabled, the phone requires your PIN each time it is switched on.
Change PIN
Use this menu to change your PIN. The PIN Check feature must be enabled to use this feature.
Phone Lock
The Phone Lock feature locks the phone from unauthorised use.
When this feature is enabled, you must enter a 4- to 8-digit phone password each time the phone is switched on.
The password is preset to 00000000. To change the password, use the Change Password menu.
Change Password
Use this menu to change your phone password. The password is preset to 00000000.
Privacy
Use this menu to lock your media contents, including MMS messages, emails, images, videos, music files and sounds:
1. Press [OK/i] to check the item(s) to lock.
2. Press Save to lock the marked items.
3. Enter the phone password and press OK.
To access a locked item, you need to enter the phone password.
If that doesn't help you, as I said, you'll need to take your phone to the local service center and ask them for help. Just a tip: bring some sort of proof of purchase or ownership so they can differentiate between you losing your password and someone else showing up with a stolen telephone.
Jul 13, 2011 • Cell Phones
I forgot the paassword to unlock my pictures and music and other stuff.
There's good news and bad news. The good news is that you might well have forgotten that the default password for Samsung phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.
First, here's what Samsung says about working with passwords:
SecurityUse this menu to protect the phone against unauthorized use by managing the several access codes of your phone and SIM card.
PIN check
The 4-to-8-digit PIN (personal identification number) protects your SIM card against unauthorised use. When this feature is enabled, the phonerequires your PIN each time it is switched on.
Change PIN
Phone Lock
Change Password
Privacy
5helpful
2answers
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
2answers
Forgot password for samsung mobile d900i
There's good news and bad news. The good news is that you might well have forgotten that the default password on the Samsung SGH-D500 phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.
First, here's what Samsung says about working with passwords on the D500:
PIN check
Change PIN
Phone Lock
Change Password
Privacy
Jun 05, 2009 • Cell Phones
3answers
I forgot my nokia 5700 music express pin code
Menu - Settings - Phone Settings - General - Security - Phone and Sim - Lock Code
code 87612,if you fail to get it working you might also try 93801
Dec 11, 2008 • Cell Phones
3helpful
2answers
Forgot Password for samsung Mobile E250
First, here's what Samsung working with passwords recovery:
Security Use this menu to protect the phone against unauthorized use by managing the several access codes of your phone and SIM card.
PIN check
Change PIN
Phone Lock
Change Password
Privacy
1helpful
Unlock code
Try this sollution:
Insert an accepted Simcard.
-Press 2945#*1201#
-Menu
-Settings
-Security Settings
-Sim Locks
-Select Lock Type
-Deactivate
NCK: 5977825?
SPCK: 825?3583
Please note that ? can be any number except 0 and 7. Try them all.
i hope it will work
so don't forgot to vote me
3answers
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
