Question about NEC Dterm DTP 16D-1 Corded Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Posted by sheri_schins on
d nixon
    New Friend:
I am having the same problem trying to program speed dial button on a series E Dterm. the instructions say to press feature, selet the speed dial button to program, then dial the number and press feature again to save the programming. So, I press feature, select the speed dial button, but when i start to press the number, the feature key light goes off and no programming is saved.
Posted on Aug 31, 2012
Anonymous
    Problem Solver:
  • 15 Answers
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Posted on Mar 29, 2010
Release forwarding to external number
To program a button to forward on Norstar (if do daily)
Feature * 1
Press spare button
Enter the * code, enter a few pasuses (Feature 78), enter the outside phone number.
i.e *88PPPXXX-XXXX
To program a canel button:
Feature * 1
Press spare button
Enter the * code
Oct 23, 2015 | NorStar M7310 Corded Phone
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
Program personal speed dial numbers on a NorStar M7324 Telephone
For external numbers press FEATURE *1, then press the button you want to store the number on, then enter the phone number using the dialpad.
For internal numbers press FEATURE *2, then press the button you want to store the number on, then enter the extension number using the dialpad.
To determine what is currently programmed on a button, press FEATURE *0, then the button to identify and the display will show what feature or autodial number is programmed on the button. If the button is a line button or line pool button, you will not be able to clear it through user level button programming. System level programming must be accessed to change line appearances.
Mar 02, 2011 | NorStar M7324 Telephone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do i turn off the DND on my KT-X7331 desk phone
Typically this is controlled by the status of the FWD/DND button and indicated by the button light.
button light off: Forward and Do Not Disturb off
button light blinking red: Forward on
button light solid on: Do Not Disturb on
The functionality of this button can be customized by the phone system installer. If the method outlined above does not work the status and activation of this feature can be accessed through the staion programminng. To use station programming press <program> then scroll through the features using the LCD screen navigation keys or enter the specific program number. To program FWD/DND the program number is 50.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Want to turn the DND off
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Dec 08, 2010 | Panasonic KX-T7731 Corded Phone
How do i change the numbers of the already programmed speed dials? The phone is a Lucent Partner 18D
If you entered them in system speed dial then you'll need to enterpgogramming on either extension 10 or 11. Enter programming by pressing feature 00,then press feature and the number of the speed dial bank (600-699), then enter in the number you want to over write. press feature 00 when finished.
If your trying to change one of the one touch buttons on the set itsself then press feature 00, press the button you want to change, then enter in the new telephone number. prsss feature 00 to exit programming.
Oct 25, 2010 | Lands Phones
How do i forward my office calls to my cell phone
Go into programming, set #322, and your extension to have permissions for forwarding.
Then, set your cell number as a speed dial at your extension. Feature 00, then feature 80 and enter the number as you would dial it from your extension.
then press a button with lights, and press feature 11xx80. where xx is your extensoin number.
When done, press feature 00 to get out of programming.
To activate, press the button you programmed the forwarding on., then the green light will come on. To un forward, press the button again.
Sep 03, 2010 | Avaya Corded Phone avaparp18d
I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
Aug 12, 2009 | NorStar M7310 Corded Phone
GE 2-9439 Phone i need the manual to store numbers in one out of the 32 speed dial buttons!
1. Press the button you want to program
2. Press the Store button (red light will illuminate)
3. Enter the phone number
4. Press Store again (red light will flash)
5. Press the button you want to program (again)
Jun 03, 2009 | GE 29439GE2 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
677 people viewed this question
Top NEC Lands Phones Experts
Ekse
Zhareese
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
