Question about HP LaserJet 4730 MFP Printer
HP 4730 MFP prints all colors correctly except for yellow, it prints about an 1/8 inch high
  • Anonymous Mar 17, 2010
    I have tried calibrating with no success.
  • Anonymous Mar 29, 2010
    Pickup rollers have been replaced, but did not help.
Anonymous
    New Friend:
I had similar problem, i checked the timing on drive section and replaced laser unit as per HP helpdesk. i replaced the DC Controller and solved the problem
Posted on Sep 06, 2010
jitendra mishra
    Champion:
  • HP Expert
  • 202 Answers
Do the full calibration three times ur problem will be resolved if problem remain same then cold reset the printer ur problem will be resolved 100% ......................
Posted on Jul 17, 2010
Walid M Sayed
    Sergeant:
  • 313 Answers
You have to make calibration
Posted on Mar 17, 2010
  • Walid M Sayed Mar 18, 2010
    try to replace th pickup rolls as described in the service manual, or imply contact me and I will send you the service manul at
    [email protected]
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
I have problem in alige colors it mixing the color in very bad way
REMOVE CARTRIDGES OUTSIDE, ALSO contacts clean with a soft cloth EASY CLEAN BELT turning smoothly
Nov 08, 2010 | HP LaserJet 4730 MFP Printer
How do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
How do i cold reset a HP CM6040F MFP COLOR LASER PRINTER It doesnt complete the initilization process... keeps hanging on step 6
restart the printer hold down 6 when backlight illuminateshold till all three lights turn on,relese 6 keythen press 3 or 9 to scrool
press 6 to select the optionu want then enter cold reset starts......
Jul 14, 2010 | HP LaserJet 4730 MFP Printer
I have no disk for a HP color lasrjet 4730 mfp and can't install on my laptop
Check out this link. You made need to copy and paste in browser.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=468689&taskId=135&prodTypeId=18972&prodSeriesId=468688&lang=en&cc=us&submit=Go%20%BB
Jul 06, 2010 | HP Color LaserJet 4730xs MFP Printer
When sending print jobs to the HP MFP 4730 device keep processing job and data led keep blinking with no printing
this problem comes due to formatter card it is faulty replacur problem will be resolvee them it will work ...........
Jun 17, 2010 | HP LaserJet 4730 MFP Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Incoming faxes on the laserjet 4730 mfp look like bar-codes. Other print jobs are OK
Unexpected image like barcode as shown below can occur when using the automatic document feeder (ADF). You are using the ADF for incoming faxes. So the problem occurs.
If the copy does not look at all like the original document, make sure that no media is on the flatbed glass from a previous copy job.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | HP LaserJet 4730 MFP Printer
Yellow shadowing on paper hp4730 mfp how do I correct this?
Try a manual calibration.
1. Press the MENU button.
2. Press the down arrow until “CONFIGURE DEVICE” appears on
the display.
3. Press SELECT.
4. Press the down arrow until “PRINT QUALITY” appears on the
display.
5. Press SELECT.
6. Press the down arrow until “QUICK CALIBRATE NOW” appears
on the display.
7. Press the “SELECT” to start the calibration.
Dec 09, 2009 | HP LaserJet 4730 MFP Printer
HP LaserJet 4730 MFP Printer Logo
467 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
