There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Unplug the notebook, take out the battery.
Hold down the power button for 10 seconds
Now replug in your notebook
If it powers on, then the unit suffered a minor surge and you should from this point use a surge protector from now on.
If it does not power on, then the unit suffered a severe power surge and now the motherboard is blown and needs replacing or buy a new notebook.
