Could be that a gear is missing (broken) on the shaft that works the 2nd and 4th gear.Check that the gear on the shaft that the clutch gear engages with does not have a sheared key.
if u find the broken part you may yout replace them to work fine.
if u have mechanical aptitude u can do it easily.
although below link does not contain your product model , u can still take help if u have problems
http://www.food-equipment.com/parts_Hobart_mixers.htm
Hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
hello! Yes, I understand...It is working with 2 speeds instead of 4 because the select switch is defective...My reference to the timer control board was for location purposes only...
if you have any questions please do not hesitate to ask............saailer
Hello! My goal is to provide the best service possible...The mixer is a 20 quart Hobart...The top two speeds are non-functional...Is this correct?
The speed selector assembly is mounted behind the timer control...The left hand knob sets the speed...the speed switch (part # 00-874831) is held in place by a mounting screw and more likely then not is defective...
I can send a link to a free pdf parts manual, for your mixer, If you would like one...
You have given a two thumb rating, Could you tell me what I missed?
Saailer
I have a HL200 that tries to turn for about a half reveloution then trips gfci. They tried to change motor and that didnt fix. Any ideas?
As I said before my mixer is working now with only 2 speeds when it used to do it with 4 speeds and I need to add tha the timer control board was replaced 2 months ago.
