SOURCE: LG LDF6810ST Dishes Wet
To save energy, the LG LDFx810 dishwasher product family does not turn on the heating element during the drying cycle (third blue light blinking) rather it brings the final rinse water up to a high temp (I think it is 160 degrees (f)) and then uses a condensing drying system (mounted in the door) to pull the wet, hot air from inside the dishwasher. When it works, the dishes come out pretty dry (except for some plastics)
Check this:
-When the DW does its final drain, confirm that the water drained into the garbage disposal is really hot and not just warm. Be careful to not burn yourself and use a meat thermometer if you have one.
- After the water drains for the final time and the dishwasher blinks the third light, put you hand under the left hand side of the DW door. There is a slot down there that should be exhausting warm air.
If either thing is not happening, it is time to get a professional to check things out and make repairs.
Please post back here with what you find or have further questions, OK?
SOURCE: I use Cascade Complete detergent and Jet Dry
Hi, I would try the new detergent packs with the rinse aid right in them to see what happens then.... I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
SOURCE: there is a white film left on dishes after the
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
SOURCE: White powder residue left on
Here is a tip that
your dishwasher.
Dishwasher
heatman101
