SOURCE: Hi, I have a Panasonic
Okay well i'll just give you the long and short. If your caller id was working and then it all of the sudden stopped working you need to call your phone service provider and notify them. If you just got these phones installed then you would need to get a caller id card and turn on the caller id prompt from your phone system.
SOURCE: How do i set up new Extention names and numbers
Extensions are named in the 004 programming section of System or Manager programming. You have to have access and a password to get there. Generally, we give everybody access to Manager programming, but your installation may be different. Extension 101, the operator's phone, by default has access, but it may have been changed.
Try page 177 forward with the 004 command on page 183 in the attached manual link. Somewhere, there will be the key to entering letters as you name the extensons.
http://public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Carl
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
SOURCE: HOW TO SET THE TIME KX-T7636
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
