Question about Kenneth Cole KC1426 (Size: ) Watch for Men
I need a replacement band for my Kenneth Cole Reaction KC1426 watch. It appears at least two different watches with different types of band fit the KC 12426 designation. My watch has two small dials within the primary dial and two push buttons, one on each side of the primary stem used to set the time / date on my watch.
Posted by k_tekrony on
5 Related Answers
Anonymous
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
Anonymous
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Kenneth cole KC1426 straps
Find your nearest Kenneth Cole retailer and ask for assistance.Visit www.kennethcole.com for locating nearest store.
Posted on Dec 18, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Cracked glass on the dial
I have no idea how the things work in India, but any Kenneth Cole dealer shop must be able to sort your problem ( at least it is worldwide experience ). So, visit your nearest Kenneth Cole store and ask for help.
Do not forget to rate, please.
Posted on Feb 06, 2009
Anonymous
  • 8 Answers
SOURCE: Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Posted on Mar 03, 2009
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
I bought my husband a Kenneth Cole Reaction watch with a black rubber band Code:NC1398 c275-47. The rubber band needs replacing because it is broken. Would you please know where I can order a new band for...
Try looking for a local Fast Fix jewelery repair.
They're in most malls nation wide,they will have one right in the store plus they do repairs for a nominal fee.
Hope this helps you a vote would be nice,Gary
Dec 01, 2010 | Kenneth Cole KC1104 Wrist Watch
Kenneth Cole leater strip
mcdevito75 here, Almost any watch repair shop can supply a new band, look for the small watch repair shops to save some money.
Jun 14, 2010 | Kenneth Cole KC1333 Watch for Men
I HAVE KC 3500 WATCH.MY BAND IS IN TERRIBLE CONDITION.
You do not need exactly the Kenneth Cole watch band. Measure the distance between watch case lugs - this will be the width of your new band. Go to any jewellers shop you like, ask them to show all watch bands of this size and choose whichever you like. Ask them to fit it as well if you do not fancy to do it yourself.
In case if you have a buckle with KC logo and want to keep it, then take it with you and ask to refit the buckle as well.
Rate me, please.
Mar 12, 2009 | Kenneth Cole RK5034 REACTION
Dec 16, 2008 | Kenneth Cole RK5044 Reaction Watch
Watch link
HOW DO I TAKER A LINK OUT OF THE WATCH BAND
THE MAHE UIS KENNITH COLE REACTION KC3555 P93-07
Jul 27, 2008 | Kenneth Cole RK5034 REACTION
Leather watch band
V377
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Jun 08, 2008 | Kenneth Cole Reaction - REACTION WIDE...
Kenneth cole watches
Link
Good day,
You might want to try above link for your need of a band replacement.
Kindly refer to above link.
Good Bless
May 09, 2008 | Kenneth Cole RK5044 Reaction Watch
Kenneth Cole Reaction band
Call 7298600 x 272 ask for a free pin for model rk 5033
Aug 27, 2007 | Kenneth Cole RK5034 REACTION
Kenneth Cole KC1426 (Size: ) Watch for Men Logo
161 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
