Question about Pramac Electrical Supplies
Portable generator head stopped making power
Portable Pramac diesel 10kw generatgr, after working fine for 36 nonstop hours, suddenly stopped making power. engine runs great. circuit breakers are ok.
Posted by rapdrp on
Anonymous
    New Friend:
Portable generator head stoped making power engine runs fine sircut brakers are fine
Posted on Mar 16, 2010
sherlywang
    Master:
  • 425 Answers
Look at the voltage ammeter on the generator control panel, if the ammeter and voltmeter on the generator control panel is still 220 V, the output empty is turned off.
If the voltmeter on the generator control panel shows a voltage of 0, then your electric ball is broken, please check if the excitation voltage is missing, and check if the three-phase winding is burned.
Post for reference:
https://www.dieselgeneratortech.com/generator-sets/Why-My-Cummins-Diesel-Generator-Does-Not-Generate-Electricity.html
Posted on Jan 29, 2019
Ifesi
    New Friend:
  • 8 Answers
Check the avr for damage
Posted on Jul 01, 2011
I have a 10kw/8kw portable generator. started up and runs fine but no ac output. checked breakers, all are on ok but no power to receptacles.is there something i can try to reset generator?
Bob,
Not sure what generator you have, but there are videos on how to test the portable generators on this page:
http://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Dec 16, 2016 | Electrical Supplies
Pramac any ideas why is my Pramac S12000 3 Phase Generator is only producing 26 volts. It was working fine at the full 400 yesterday. It is just over 2 years old but has only operated for about 40 hou
The first thing I would look for would be internal fuses blown. This sounds like a 460 volt 12,000 watt industrial generator and you probably should call the installing contractor for service. My 15,000 watt generator is over 30 years old and has less than 700 hours on it and those are mostly test-run hours.
Dec 13, 2014 | Pramac Electrical Supplies
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Dec 09, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
GE Generator 10kw model #040448. TRANSFER SWITCH FAULT message being displayed. Generator works fine. Generator output load voltage = 233V.
This generator has a built in transfer switch. If you do not have an external source of 240 volts going in to the unit (utility power), the transfer switch will show a fault or "abnormal" reading. If you do have utility power going in to the transfer switch, and the generator is on then you have a faulty transfer switch. It is time to warranty or get a replacement switch.
Sep 09, 2013 | Watts Onan Portable Generator - 5000 ,...
500kva 380 volt diesel generetor
make sure gen isnt stopt on protection overtemperature or oil level or coolant level. try to bridge protections one by one to find the course. first make sure all fluids are on level and coolers are clean. fanbelt tension and coolantthermostat can also be wrong.
Jan 23, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Can u esplain about trouble shooting in diesel generator
my 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
Oct 25, 2009 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Motors fine, but no electricity - coleman 6250
pramac bought them out i just order parts today oct-15-08 call1-800-445-1805 took me awhile to get a hold of someone but she seemed to know what was going on. my guess is that the printed curciut board in the back of the generater head is bad i have had to change alot of these out.
Oct 08, 2008 | Coleman Powermate Premium Plus 6250W...
My powermate pm0647000 stopped generating electricity.
Flash it !
Start your generator, plug a single speed drill into the recepticle, while the generator is running make sure the drill is in the forward posistion then turn the drill chuck couterclockwise with your hand untill your generator power's up.
This simple fix " excites " the stator.
Good luck !
Sep 29, 2008 | Coleman Powermate Premium Plus 6250W...
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
942 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Robert Wooley
Robert Wooley
Ngoro
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
