Question about Sharp AL 1631 Copier
Fixed a paper jam on the sharp al-1631 and now get a L 1 error what do I do?
Posted by vercruysse on
abbas rezazadeh
  • 328 Answers
Scan unit doesn`t move unlock .is under the scan
Posted on May 30, 2010
5 Related Answers
Anonymous
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to [email protected]
Posted on Feb 15, 2008
Anonymous
  • 32 Answers
SOURCE: Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Posted on Jul 23, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: flashing p and paper will not feed it jams
Clean the paper feed roller under paper tray use izopropilic alcool.
Posted on Sep 27, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: Not 'grabbing' the paper!
they are rollers made from rubber it is same as when the tire on a car will be slide out and the car will slide on ice and rain, well here when they will waste they will not pull the paper, only solution is to try to clean them with glass cleaner and if this not work they will have to be replaced
Posted on Jan 28, 2010
sgttbone
  • 30 Answers
SOURCE: I have a Sharp AL-1631 Copier. The 'P'
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
Posted on May 16, 2011
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
May 13, 2011 | Sharp AL 1631 Copier
We can not clear the paper jam error. We have cleared the paper jam, turned the unit on and off, unplugged the unit, moved all the rollers, can not see any pieces of paper that are still in the misfeed but...
This copier has 4 sensor
1. paper sensor
It is called paper sensor its installed paper tray
2.Drawer sensor
3. Drive sensor its installed middle position
4. Exit sensor it is in fuser unite.
May be any sensor displace or broken.So you should check it.
Good luck.
Feb 16, 2011 | Sharp AL 1631 Copier
I had a jam in the paper try bypass, removed the jam, but the indicator light continues to blink. What's going on and how do i fix it?
open and close all doors on the copier ending with the front and side one.
make sure it is indicating a jam and not asking for paper in the bypass tray
Good Luck
Jan 15, 2010 | Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Sep 27, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
Nov 19, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
