Whirlpool AKZ159IX Oven Logo
Question about Whirlpool AKZ159IX Oven
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Posted by jmilly on
Anonymous
  • 69 Answers
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Posted on Mar 16, 2010
I have a brand new Viking french door oven...Went to set it at 450 on bake setting and got an F02 error code. How do I fix this?
Fault F02 is indicating an overheat fault- service manual says to replace main electronic control board.
Sometimes switching off at wall will clear the fault.
However, switching off at wall will reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears. Good luck!!
I have a westing house 509 fan force oven the fan turns off when i turn oven off but the element still goes and goes and goes why
This sound like a switch problem, when you say turned off is the element glowing because the oven light is not working, or it has to be switched off at the mains switch to stop heating, could you clarify.
Nov 03, 2014 • Ovens
Cannot switch off oven fan.
WARNING
Go back to the switchboard and turn the oven OFF, (Switch the fuse off at the switchboard)
Your Oven sounds like it has shorted out.
DO NOT TOUCH IT
It could be live, Electricity can cause serious injury and even death,
Get a Registered electrician to check this for you. DO NOT use it.
Looks like you might be ordering out for dinner tonight :-)
Take Care
Feb 09, 2014 • Ovens
1helpful
I have just replaced the fan for this oven as it had stopped spinning. However it appears not to be the fan that has broken as the new one behaves the same. One important obserbvation is that when you...
Strange one this. According to the wiring and circuit diagrams, the yellow wire from the fan should go to contact 4 on the main oven switch. The oven element is connected to the thermostat, which in turn is connected to contact 3 on the oven switch. When the oven is on the handbook says that contacts 1,3 and 4 are made, contact 1 being the oven lights. So if the lights come on and the fan turns, the switch is more or less working. The only other thing that overrides the oven element is the thermal cutout. If you still have the problem, let me know what the thermostat neon is doing in all of this. It will be interesting to see what this is doing. Also, if you want the handbook which includes the diagrams, post your email address and I will send you a pdf copy.
2answers
Lincoln Conveyor oven Md. 1000 Suddenly turns off
Check the burner-blower centrifugal switch (S5 on the wiring diagram).
I can't turn off the main fan oven?
Sounds like the oven thermostat is faulty, giving a permanent feed to the fan and element.
I would say that it is worth having it put right.
Hope this helps.
Dec 13, 2009 • Ovens
2helpful
2answers
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Upper cooling fan constantly running
not sure of location but either on roof of oven or at the back close to the fan, but there is a fan start stat that turns the cooling fan on and off. could be stuck in on mode. only cure is to replace
Top Whirlpool Ovens Experts
W.L.
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
