Copytechnethttps://www.copytechnet.com > ... > Canon
Nov 26, 2020 - Check the connection of the Flexible Cable between the DC Controller PCB (UN9) and the Main Controller PCB2. -- removed and re-connected ribbon ...
GM OBD Trouble Code 26
Quad Driver Module (QDM A) Error
The ECM uses "quad drivers" to control its output devices. Each quad driver is capable of controlling up to four devices. Fault Code Description
26 - Quad Driver Module (QDM A) error
Symptoms
Improper operation of an ECM-controlled device
Common Problems
Code 26 does not mean there is an internal ECM failure
Code 26 can indicate a circuit problem (open or shorted) in one of the devices controlled by QDM A
Some diagnostic charts may state which devices are controlled by QDM A. In other cases, it may be necessary to monitor which ECM-controlled devices are operating when the Check Engine Light comes on in order to determine which circuit is causing the problem.
Chris, it would be helpful if you would provide the MODEL to better diagnose the error codes. Here is a general error code that may or may not include your model (because I don't know what model you have). It does cover the Prestige Sole 24 - 32 - 50 - 75 - 120 and Prestige Excellence 24 - 32.
Error Code E 03 Indicates Rectifier or gas valve error and the Resolution of the fault is to Replace the rectifier or gas valve.
Error Code E 08 Indicates Air Pressure Switch did not close and the Resolution of the fault is to Check the air pressure switch. Without your exact MODEL, this is the best answer I'm able to provide, I hope this helps you.
Appliance tech has a computer program or hand held device that has the answer. Newer machines are built to that spec. F3 shows where the main component of the error exists. #26 may not be a commonly occurring error. Go to Google and type in F3-26 or something similar. See what happens. Failing that contact a repair Company or your trusted Tech.
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
