G'day,
I have a Motorola SBG900 cable modem that offers wireless network, and I'm trying to get a TP-Link TL-WR841ND to connect to act as a bridge to the SBG900 wireless network.
The TP-Link finds my Motorola wireless network and appears to have no difficulty connecting to it (no errors reported when doing so) but when connecting the laptop to the LAN points on the TP-Link I have no internet access.
Info:
- My broadband cable entry is connected to the SBG900 (and works OK for the directly connected PC)
- I can connect OK to the SBG900 using a wireless laptop (and has full network connectivity)
- I believe I have correct WEP keys (to enable the TP-Link to connect to the Motorola SBG900 cable modem) configured (same wep key as the wireless laptop that connects OK)
- The laptop (Win XP Pro - SP2) has settings of "obtain IP auto" and "obtain DNS auto".
- There appears to be significant data passed between the laptop and the TP-Link (network connections see many Mbs of data transferred between them)
- I have updated the TP-Link to the latest firmware
SBG900 info:
WAN IP 60.224.128.48
LAN IP 192.168.0.1
WAN:
Static IP = 60.224.128.48
WAN default gateway = 60.224.128.1
TP-Link TL-WR841ND info:
Default IP = 192.168.1.1
Sorry to be a network newbie but it's frustrating me no end, so any help would be appreciated...
Cheers,
Andrew
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
SOURCE: Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
SOURCE: Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
SOURCE: Motorola SBG900 WEP password problem - MAC OS X
Optionally, try holding the reset button for 20s and access through wireless if you want.
SOURCE: Ok this is my problem i have a time warner arris
The default username and password for most routers I have seen is admin and admin provided you have not changed it. All are lowercase letters.Also I suggest you use the WPA or WPA2+ encryption if its available. The WEP is easy to crack wirelessly and I had a gala time cracking my neighbor's router in less than 3 hours!
Testimonial: "thank you very much even tought the default doesn't work because it doesn't have a default gateaway it says 0.0.0.0"
