EJ K.'s solution is incorrect, theree areonly one set of power input connections to the phone via the mini/micro usb connector regardless of the charger being used. People who do not know the specs should not try to answer these things, That person is dead wrong.
Your problem is your battery is beyond it's service life and needs to be replaced. thats all that there is too it. These small batteries are pushed to the limit with the power drains that we put them through and are good for only about a year of reliable service of average use. The problem is most people over use their cell phones, as the small phones like the V3 were never meant to be used as primary phones.
What you are describing is that there is an issue with the USB charging port on your V3i. Different pins are used when charging via the wall as opposed to via a USB computer port. It really is quite common with the V3i, you can search on the internet to get your port repaired. If you cannot find anyone, feel free to ontact me, outlet3g in the repair directory.
Good luck!!
