Question about Canon PIXMA MP530 All-In-One InkJet Printer
My Canon MP530 printer has error code of 6A00. Can you help?
Posted by tedandpamsta on
Clive
  • 4,345 Answers
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 16, 2010
George Hsu
    New Friend:
    Problem Solver:
  • 3 Answers
There was no paper jam in mine. So I thought it must be the purge unit that was the culprit. But the purge unit is stuck in a hard to access corner inside the inner cover. I thought I had nothing to lose but to try to clean the purge unit..... I cut paper towels into samller pieces, wetted a few pieces with water, then just extended my hand into the purge unit area and started wiping it. Man there was a lot of blue ink in the purge unit. I had to clean it many times, and carefully tried to wipe all surfaces of the purge unit as much as I could, then wipe it dry with a few pieces if dry paper towel. Then I tried to turn on the printer, and voila, it did reset successfully. 6A00 error message disappeared. Thank you for the pointer. It saved my MP530.
Posted on Dec 27, 2012
5 Related Answers
Anonymous
SOURCE: printer displaying error code 6A00??? I'm very puzzled...HELP!
I am getting the same error. What is the solution.
Posted on Dec 26, 2007
Anonymous
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
Anonymous
SOURCE: canon pixma mp530 problem error code 5100
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
komguy
Craig Gillette
  • 2306 Answers
SOURCE: Canon iP6700D error 6A00
6A00 is a purge assembly error, thats the cleaning unit on the right where the printhead parks. Look on the right with a flashlight and see if there's paper, or anything that doesn't belong. If the wipers are jammed into the pad assembly, you will need a new purge unit, best changed by a shop.
Posted on Aug 08, 2009
Priya darshan
  • 3422 Answers
SOURCE: Canon MP830 error code 6A00
HI,
Please the pixma off and open the lid.Now manually slide the cartridge-tray to the left.
Use a piece of tissue to clean the base-pad where the heads are stored.See if it is stuck in a kind of upward position and look if the mechanism that moves the tray is released if not then touch it and it will be loose. Remove all ink residue, move the tray back to its most right position and close everything.
Let me know if you still get the same error.
Thank you
Posted on Aug 13, 2009
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
I'm getting an error code of 6A00 on my Canon Pixma MP530
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Dec 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Show the code 6A00 and the printer won't print. The lcd reads check printer then flashes 6A00
That error indicates a sheet feeder error, apparently its not something you can fix yourself and you will need to send it in for repair.
You will need to send it too an Canon approved repair center, calling Canon and asking them should reveal where to send it.
Aug 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 - Check Printer - 6A00 error
Hi
Hope it will work for you
Solution 1:
Solution 2:
Solution 3:
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
MP530 alarm and 6A00 error
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
ERROR 6A00
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=832&modelid=13371&keycode=2118&id=27509
this is a script error which can be fixed using this link i looked up the information for you.
just download from link this should help
May 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,186 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
