SOURCE: doesnt solve integrates and derivatives
If you are using X as your variable try this. Hit the F4 key, press 4 and type X. This will delete the variable x from memory and you should be good to go.
SOURCE: Differentiating and Integrating Problems
This means that you are using a non-algebraic variable in an expression. I know, I am not even paraphrasing. Exemple: if you write 2 + johnQ, where johnQ is a table of data, a picture or a GDB, graphical data base object.
Here is an exemple where mat is a 2X2 matrix and mot is a table.
Hope it helps.
Here, We deal with Some Special Products in Polynomials.
Certain products of Polynomials occur more often
in Algebra. They are to be considered specially.
These are to be remembered as Formulas in Algebra.
Remembering these formulas in Algebra is as important
as remembering multiplication tables in Arithmetic.
We give a list of these Formulas and Apply
them to solve a Number of problems.
We give Links to other Formulas in Algebra.
Here is the list of Formulas in
Polynomials which are very useful in Algebra.
Formulas in Polynomials :
Algebra Formula 1 in Polynomials:
Square of Sum of Two Terms:
(a + b)2 = a2 + 2ab + b2
Algebra Formula 2 in Polynomials:
Square of Difference of Two Terms:
(a - b)2 = a2 - 2ab + b2
Algebra Formula 3 in Polynomials:
Product of Sum and Difference of Two Terms:
(a + b)(a - b) = a2 - b2
Algebra Formula 4 in Polynomials:
Product giving Sum of Two Cubes:
(a + b)(a2 - ab + b2) = a3 + b3
Algebra Formula 5 in Polynomials:
Cube of Difference of Two Terms:
(a - b)3 = a3 - 3a2b + 3ab2 - b3 = a3 - 3ab(a - b) - b3
Algebra Formula 8 in Polynomials:
Each of the letters in fact represent a TERM.
e.g. The above Formula 1 can be stated as
(First term + Second term)2
= (First term)2 + 2(First term)(Second term) + (Second term)2
Check the names of all your variables. One (or more) of them is conflicting with something in memory, such as a text file. And make sure you explicitly specify your multiplications. If you say "ax" you might mean "a multiplied by x" but the calculator will take it to mean a variable called "ax". And if you have a text file named "ax", that is most definitely a non-algebraic variable.
