Question about Microsoft Xbox 360 Controller
Why wont my xbox controller connect to my xbox
Why wont my xbox controller turn on my xbox even if its connected through wire. its the controller that comes with the xbox and its connected to the usb port, its weird
Posted by j_espe on
Anonymous
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
You cant just Turn it on by the middle button you have to hold the middle button and the start button at the same time for 3seconds then it will turn on.
Posted on May 09, 2010
1helpful
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
7helpful
One of my xbox controllers wont connect to the xbox the controller turns on but it wont connect ive tried everything thats been posted but nothings worked. i have two controllers and the other one works...
You've attempted to sync it right? You click and hold the sync button on both the xbox and controller until each one is spinning around. Then it should grab and connect. hilldav9.jpg
2answers
How to setup two wireless controlers to an xbox
  1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
  2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
  3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
  4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
  5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
  6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
  • The controller remains connected to the Xbox console even when you turn off the Xbox console.
  • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
  • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
  • If the controller does not turn on, the batteries may have to be replaced.
5helpful
My controller and xbox wont connect
To connect the controller to your Xbox 360 console, follow these steps:
2answers
My xbox 360 and wireless controller will sync but then it wont show that they are connected and even though i turned on my console by using the button on the console it just shows the green light turn on...
  2. Make sure that your Xbox 360 console2_bing.gif is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console2_bing.gif.
  5. After the Ring2_bing.gif of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
2answers
The connection from my controller to my standard xbox wont work!
you may have a shortage in your controller cord and may need to buy another one
Even when i press the sync my controllers still dont connect
what you do is turn on your 360 and controller and press the white connect button and your controller
should connect
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Joseph Murphy
Joseph Murphy
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
