Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers
The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals).
Setting the Extra Speaker Terminals
Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver.
1. Press the On Screen button on the remote control to enter the On Screen Menu.
2. The On Screen display should be displayed on the TV/Monitor.
3. Press the Arrow Down button on the remote until Setup comes up in the screen.
4. Press the Enter Button on the remote control.
5. The Setup Menu will come up across the TV/Monitor screen.
6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker.
7. Press the Arrow Down button on the remote to select Manual Setup.
8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu.
9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up.
10. Press the Enter Button on the remote control to enter Power Amp Assign menu.
11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted.
12. Press the Arrow Down button on the remote to select 7ch+1ZONE.
13. Press the Enter button on the remote to select 7ch+1ZONE.
14. Press the On Screen button to exit the on screen menu.
To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver.
Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Hi my name is Mike Houston of DISH Network and I see you arelooking for the remote codes for your Yamaha RX-V795 5.1. The codes are; 733,747, 730, 731, 732, 745 and 663. To address the remote to the Yamaha you willwant to press and hold the desired mode button (TV, VCR, and AUX) until theentire mode button backlights come on, then release. The next thing you want todo is press the number 2 and enter the three digit code (the light will blinkoff after each digit is entered and then return to a steady light.) After youenter the 2 and the three digit code press the Pound (#) button, if the codeentered is valid for the remote, the mode light flashes three times. If thereare anymore questions please e-mail me at [email protected].
You have a power audio amplifier problem.The blinking is an error code,common on latest TV,audio/video and all electronic appliances. The one that you have is your Audio Power amp is defective,it needs replacement of main Audio Power IC,do check the caps too.
If you've set up the speaker levels according to the manual (you DO have the manual, right?) and the rear speakers worked then, maybe your program material has little audible surround going on.
It's not blown.
Has anything been spilt on it, if so take the batteries out, pop it apart and remove the rubber backside, and circuit board, wash them with a damp rag, (not detergent) and let dry, then reasemble.
Get into the cable box menu and look for audio settings, chances are your digital output from the cable box is off. If you still can't get audio, reply with your Cable Box Make & Model and I can help you further. Hope this helps
