THE LED ON THE RECEIVER IS DISPLAYING REAR CHECK.
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
hi...im not sure how it happened...what i did was i pressed 0135, the main unit lit up and i pressed the id set or something like that on the back of the wireless reciever.....well the main unit should be back to red and once i pressed the id set i accidentaly pressed the power button so the main unit turned on...then i waited for the wireless reciver to boot up and worked.....
SOURCE: problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
SOURCE: just connected the SWA-4000 wireless
Actually the SWA-4000 IS compatible with the htz-310t. I'm using the htz-310 system with an SWA-4000 and it works perfectly fine. under the list of compatible systems with the SWA-4000 you'll see the htz-310. so i don't know where the other answerer is getting his facts.
once you press the nubmers on the remote, 0, 1, 3 5 or whatever the numbers are. turn the system on with the on button on the system not of the remote.
if the blue led is on on the swa-4000 then it's communication, there's a link.
if you do a sound test it will not send the static to the rear speakers, at least it doesn't for me. however there IS sound ouf of those speakers. so i know they work.
SOURCE: Can a new tx card be used in a swa-4000
where can you get a tx card from, because i need one and yes it can as long it is for that specific wirless module ?
