Question about Toshiba 50H81 50" Rear Projection Television
The touch focus on my 50h81 says touch focus error, the red vertical is crooked. There is a red and touquoise line surrounding everything on the picture.
Posted by bj_u on
Chi Chu
  • Toshiba Master
  • 8,457 Answers
Ur convergence is dead.U must know how to solders?Must replaced 2 convergence ICS,and some or all the resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost $300 for parts,and labors.
Posted on Mar 16, 2010
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
When I run the Touch Focus , it ends Touch Focus Error, and the Red Verticle line does not move , the Horizontal is bent .. now tv is fuzzy?
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 27, 2009 | Toshiba 42H82 42" Rear Projection...
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Replaced stk's but I still can't move the red vertically
Did you replace both the convergence ICs ?
The auto-focus won't work properly until BOTH Convergence amps are replaced .
Also you need to replace various resistors along with it .
Feb 25, 2009 | Toshiba 50H81 50" Rear Projection...
Convergence problem
Replace the Convergence amplifiers. Mine did the same. It was like watching a 3D movie without the glasses. It is not hard to do for someone who knows their way around a circuit board repair. Otherwise call a reputable service shop.
Jun 17, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba
your convergence ICs need to be replaced. There are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jun 05, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Projection TV
youre convergence ICs need to be replaced there are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
May 24, 2008 | Toshiba 50H81 50" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Touch focus
I thought this was a place to get help not yelled at!
Jun 05, 2006 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
161 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
