Question about Behringer EUROPOWER EP2500 Amplifier
Nothing comes on on a europower ep2500 power amp
Posted by stevejohn702 on
Scott Frye
    Genius:
  • 1,175 Answers
Hi...
Check fuse in the rear where AC comes in and there should be a couple of small fuses ( 20mm long ) inside the amp. CHeck those too
Posted on Apr 18, 2010
Audio input line
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
1helpful
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
1helpful
2answers
Europower Behringer EP2500, clip lights turn on when main power is off
Depending on the age of the amp,there is a possibilty that the amp my have damaged lanes or tracks to the pre-amp section to the front of the amplifier.
The weight of my Europower PMX2000 Beheringer mixing amp. I have a weight limit for flight issues.
For that power the amp is fairly light. The USUAL solution is that musicians RENT equipment near their venues to avoid shipping expense. Your equipment is also very vulnerable to damage during flight.
What wattage speakers do I use with europower ep2500
Wow thats a serious system you have there.God help the neighbours!Anyway here is an example.you need a pretty serious speaker.At 8ohms,you would need something like a 8ohm 450watt speaker system.Anything smaller will stress your amp if you turn it up.The amp would kill smaller speakers or the amp internals(channels)at higher volume.It would be like hooking up a garden hose to a fire hydrant.Something would have to give.hope this helps and happy listening
1helpful
My europower ep2500 amp the braker trips when I power it on
Hi,circiut braker trips only when the load on it is to much.
That is carry what is bigger than it watt, or can not carry too well. If you have another amp., you can put some load on that to reduce to braker always tripping off.
If that is the only amp. you have in what you are doing, just reduce the amp. volume to half(setting at 12 O CLOCK). it will work, but will not be too loud as before.
Take care.
3helpful
2answers
Trips on power up
It has a short circuit on the final steps of the outputs, maybe the common called "final transistors or power amplification IC (integrated Circuits)"are blown. You don't have the ability to resolve this problem, so take the unit to a facility authorized repair.
1helpful
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
2answers
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
3helpful
Behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Behringer EUROPOWER EP2500 Amplifier Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Kardoc
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
