Question about HP OfficeJet Pro L7580 InkJet Printer
How can i add an HP printer officejet pro L7580
How can i install an HP printer officejet pro L7580 wihout the CD disc?
Posted by andrew_chris on
Dushyant Bist
  • 776 Answers
All the software/drivers for your HP printer can be installed by clicking on the link below:
Just select the OS you use, and you are good to go for the free download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=2512008&#
Posted on Mar 15, 2010
Where do you find a driver for the Officejet Pro L7580 for an Mac
Good Day Nicholas!
You can find the HP Officejet PRO L7580 driver for MAC from the download link below
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=219&lc=en&cc=us&dlc=en&sw_lang=&product=2512008#N199
Please don't forget to rate my answer.
Jul 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Running Vista Home Basic and tryin to install L7580 but
Most printers come with two cds one for MAC and the other for windows. Make sure you have the right one inserted. Also make sure your printer has drivers for vista. It wouldnt hurt to check to make sure your system is malware and virus free before reinstalling. and if you are infected clean the infection out and remove restore points and make a new one. If you dont remove infected restore points you will just reinfect the machine.
May 16, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Please provide driver for HP Officejet pro L7580 operating system window vista
http://www.userdrivers.com/Printer/HP-Officejet-Pro-L7580-Color-All-in-One-Basic-Driver-for-Windows/
please rate
Jun 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When I try to scan, it reads "No Scan Options".
Try scanning from the solution center. If successful, check the scan button settings if you can see applications available on the 'Destination List'. Add all the application to the right side. Close the solution center and try to scan.
Mar 23, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printhead replaced; still says yellow is empty
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My computer won't reconize my software it has found the computer
I have miss place my CD for my Office Jet Pro L7580. I am trying to add to my mac computer. Is there a way to add to my mac without the CD?
Nov 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 InkJet Printer Logo
163 people viewed this question
Ekse
efs_perpends
efs_perpends
